**My Horn Starts My Car - HELP ME
Old Jul 17, 2008 | 04:34 PM
Cxrazy's Avatar
Exclamation **My Horn Starts My Car - HELP ME
Okay fellahs.
This one's crazy.
Earlier today I installed a Nautilus Horn in my Taco. I installed it and pushed the horn with the car off, and we have hornage. :p (is that a word?) Anyway, the horn blew and everything was dandy.
So I get in the truck to take a drive, and I start the car. Everything feels just as it should. Since I had just installed this horn and wanted to give it a try, I hit the horn. The starter proceeds to grind and the car almost dies. :eek: :eek: I then proceeded to pull over, and turn the car to just before grinding and hit the horn. The car starts right up. And also, the horn doesn't work when the cars on. It just cranks the starter.
Why would the horn work fine when the key is out, and in the Acc placement, but start the car while in On (as far as you can go before cranking)?
I can draw out the relay/how its wired if that would help....
THANKS!
Old Jul 17, 2008 | 04:59 PM
Mr_Martinez1982's Avatar
yea how you wired it may help
im pretty sure you got power from the wrong source. or are grounding where you shouldnt be (very helpfull huh?) found this, may be it helps http://www.commandocaralarms.com/wir...coma/1580.html
Old Jul 17, 2008 | 05:08 PM
Robert m's Avatar
we need video of this
Old Jul 17, 2008 | 05:09 PM
Cxrazy's Avatar
......_
Imagine that is a relay.
Top - 20A fuse to battery
Left - Ground
Right - Wire from old horn
Bottom - (+) on new horn
Just like the wiring diagram said on the horn. Maybe I grabbed the wrong wire to the horn? There were 2, but I got the + one.
I'll throw up a video sometime.
Old Jul 17, 2008 | 05:39 PM
LMAO, that IS crazy.
Maybe you should check both wires for voltage and continuity to ground, with key on (ign), an key off, an if possible while someone presses on the horn, both key on, key off. then wire your relay accordingly.
ill be honest, i dont see how you adding a relay would interfere with the start circuit. You are doin the wiring @ the horn and not under the dash, right?
Old Jul 17, 2008 | 05:43 PM
DeathCougar's Avatar
*subscribed* this thead has potential for the classics forum.....
Why not just leave it wired up? Then you could wire a switch to the main ignition switch for on/off, and use the horn to start it! Pure genius!
Old Jul 17, 2008 | 05:48 PM
nix4x4's Avatar
Back it up....
So, by hittin your horn (only hitting your horn alone), your truck's engine will fire up?
That is the single most rediculous thing I've ever heard. Must admit, cool though...
Yeah, we really need a video of this
Old Jul 17, 2008 | 07:48 PM
aviator's Avatar
ROFL... I'm sorry but this is classic... sounds like a tool man thing...
on the other hand it would make a great theft deterent...
The horn on toyotas [up to 95 anyways] is actually switched through the neg. side not the positive so that might have something to do with your problem though i really can't see how the horn circuit could get crossed with the starter circuit...
Old Jul 17, 2008 | 07:50 PM
Cxrazy's Avatar
Yes. With the key in the ignition and turned to On.
Old Jul 17, 2008 | 07:53 PM
Circuits on our trucks are wierd. Did you know you can run a lead from the cold start injector plug to the battery, and the truck will turn over? Not sure which side of the plug it is, but if one side doesn't work, the other will!
Go out and try that tomorrow....you will be amazed!
Old Jul 17, 2008 | 07:54 PM
904_runner's Avatar
Sorry can't help you other than recheck every connection you made.
We need vid of this!
Old Jul 17, 2008 | 08:03 PM
Spence1016's Avatar
tim taylor the tool man lol
Old Jul 18, 2008 | 01:06 PM
TexanTaco's Avatar
That is crazy, and really funny
My family had a '87 Jetta with tons of electrical gremlins. My favorite was the horn would sometimes go off when the car was in reverse. It was kind of like the reverse beep forklifts have.
Old Jul 18, 2008 | 01:45 PM
corax's Avatar
make sure you didn't run a screw through any of the wires when you put everything back together
Old Jul 18, 2008 | 02:39 PM
ozziesironmanoffroad's Avatar
do what i did cut the old horn wires off the horn and put em on the new one. easy huh? i thought so. and x3(or whatever number) on a video!
Old Jul 18, 2008 | 03:17 PM
Kinked's Avatar
now THIS is a story that can (and probly will) be told in many places
Old Jul 19, 2008 | 08:47 PM
kmcaprice14's Avatar
one word... awesome
Old Jul 20, 2008 | 08:11 AM
Ironmike4x4's Avatar
Sounds like a short to power on the supply side of the starter circuit as it will not do it until the key is in. Backtrack your wirings and make sure you did not cross any wires to the wrong circuit. Also check any screws or grounds you've put in as I've had an Impala Police vehicle that would shut the car off when the sirens were put on. After 3 weeks of searching/testing wires I found a long screw to be the cause from the power side of the siren was shorting to ground a normally open relay for the pump to close when the siren was on.
Old Jul 20, 2008 | 09:47 AM
scuba's Avatar
Giggiddy Giggiddyyy
Old Jul 20, 2008 | 09:48 AM
