My favorite things always come in pairs =)
Got my LF170s in today. Going to go mount them now. Quick question for you guys. I still have my wiring intact for the foglamps (now removed). Can I just run wires from these to the foglamp wires? Also what type of wire do I need to pick up? I don't know anything about electrical work. Other then red is positive, and black is ground.
pics below
pics below
Holy cow dude, I thought my pics were big!
I'd just match the gage wire you got to extend it and wire it up to the existing stuff if possible. If not, did it come with a wiring kit? I got a basic write-up on my website how I did my Hellas, but it came with everything I needed. If not, I could AIM you through it perhaps...
Just stick the lights in your ears and grab both poles on the battery!
So the gauge wire I'm assuming is written on there somewhere. It has a wiring kit for $30. But I figure I already have a switch and pre-wiring done, no need to spend extra money. ... my cheap ass side kicking in.
You can AIM me and we'll see if I can help that way...rather than just post repost post repost etc
I extended the wires from my factory foglights using 16 gauge elec. wire when I put the Hella 500 on the TJM. The Hellas are not polarity sensitive and I don't know if the LF are. Did you have the little factory fogs on your stock bumper? Those are the wires I extended for the Hella 550.
George
George
I mean I know what it does .. but what does it look like
You HAVE to use these... They pop into the lamps on the top (bottom? I can't remember) and allow clean air to circulate through the lamp. The warranty is void if you don't use 'em.
also the guy gave me 24 gauge wire .. should I have gotten something different .. like 16 (george).
As for tapping into the fog lamp harness, I wouldn't really suggest wiring straight to it, I think it's too light. You _can_ use the fog lamp wiring as a trigger for a dedicated relay.
Originally Posted by midiwall
NO NO NO! Do NOT use 24 gauge wire with these lamps - it's too small for the current that you'll be pulling. You should be using at least 18 gauge wire.
George
Originally Posted by george16
You can still wire it up directly. Remember, the stock foglight wiring already has a relay in the fuse box.
Ummm, but isn't the stock fog wiring like 20gauge wire? The point being that the stock fog lights draw a lot less current than the LF-170's.
. George
Anyway, how much do the LF draw? What's the wattage of the light bulbs?
The LF 170's use 100 watt bulbs, so they're pulling 8 1/2 amps each.
You know, when working on the truck.
