Muffler Tip
Old Aug 30, 2004 | 08:45 AM
2002 SportEdition's Avatar
Muffler Tip
Muffler Pros:
Will it do any bad to your engine if you have the exhaust tip smaller than the exhaust pipe? I mean, can I use the 1.75" - 2.0" tip on the stock exhaust with 2.25" pipe (2002 model)?
Old Aug 30, 2004 | 09:28 AM
Flamedx4's Avatar
Yes, it is bad. BUT, how would you put a 2 inch tip on a 2 1/2 inch exhaust in the first place? Slip it inside? Use an adapter? If you managed to do it, it would cause restriction which is last thing you want.
Old Aug 30, 2004 | 11:59 AM
I bought a very nice "Pimping" tip which has 3" inlet Diameter and the outlet diameter is 3.5" with 2" Resonator. It is a slip-on tip.
So, this should not and cannot be used???????????????
Old Aug 30, 2004 | 12:15 PM
lee's Avatar
lee
hahah. thats what receipts are for
Old Aug 30, 2004 | 02:03 PM
Flamedx4's Avatar
You sure you don't have it backward there? Look in it and see. EVery resonator tip I could find specs for has a resonator insert that is larger than the pipe it fits. (i.e. 3 1/2" chrome tip with 2 1/2" resonator insert fits up to 2" pipe. etc)
Old Aug 30, 2004 | 03:44 PM
This is what I have.
Specs:
Fits 1-1/2"-2-1/2" exhaust pipes
3-7/8" outer diameter
3" inner diameter
2" Resonator diameter (Not really 2" though, about 1.75")
Roughly 7-8" in length
Simple, 3 turn-screw installation
Old Aug 31, 2004 | 09:29 AM
Flamedx4's Avatar
looks like it's okay, the "fits 1 1/2 to 2 1/2 pipe" and the 3" inner diam is the key items.
Draven023
13
Oct 8, 2015 04:43 AM
hiluxinargentina
Sep 30, 2015 11:12 PM
voiddweller
Sep 28, 2015 11:21 PM
Keithstoyota
Sep 27, 2015 07:29 AM
