Motor thats been sitting for awhile
I got a 3.4 motor thats been sitting for who knows how long. at least 2 years. suppose to have been started since then though.
There is low compression in all 6 cylinders. 110 at the highest and 20-40 At the lowest. Sounds like rings are stuck because you can hear the air going out the bottom past the rings on all cylinders.
From: Shelburne, VT previous: Everett, WA; Bellingham, WA
I have 5 gallons of beer fermenting in the closet. It's going to be a Golden Ale. The yeast did a good job.
I don't want anything from the rest of you, I just want you to know what I know.
Yea if penetrating oil over a 24-48 hour period does not free up the rings i would suggest the engine be repaired/rebuilt.
Sure its even in the rings? And the timing belt is not broken? 20-40 psi is extremely low for a 3.4....
I think if i remember right the 3.4 is a pretty high compression engine and i think normal compression is a little over 200 psi..
I would look at the engine timing.. i suspect timing belt failure...
Check the timing first, and try to do a leak down test. If all else fails try sealing the cylinder's off with a airgun and try to pressurize them. That should give you an idea of where your compression might be escaping. If it is indeed rings try mixing diesel, atf, and Marvel mystery oil. I have unsiezed engines that way a few times and it works pretty darn well. It may take a while though.
X3 on the WD40! Spray the piss a lot in the SP holes and let them sit. You can use Marvel Mistery oil as well it works great. Then before you start it pour some marvel in the oil works great at lubeing up the top of the heads.
Good luck
Good luck
get a couple table spoons of marvel in there and let it sit for a couple days. Rotate the crank every day for a couple minutes to make sure its getting into the rings. normal compression should be around 175-190
Flying91
45
Apr 11, 2024 04:39 PM
jasonty
41
Dec 23, 2018 01:00 PM
Sep 4, 2015 09:27 AM
v_man
Jul 23, 2015 04:01 PM
