motor oil
Old May 23, 2005 | 06:05 PM
slammdrider's Avatar
motor oil
where can i get cheap yet good synthetic motor oil i want to change my oil soon and dont really want to pay 6 or 7 dollars for a quart of oil.
Old May 23, 2005 | 06:11 PM
Glenn's Avatar
You can get Mobil 1 at the Puyallup Costco.
Old May 23, 2005 | 06:37 PM
User 051420's Avatar
Mobil 1 gallon jugs are pretty inexpensive at Wal-Mart, too.
Old May 24, 2005 | 08:59 PM
kyle_22r's Avatar
i don't think you're going to find any good synthetic for under $5 or so a quart. though looking on some oil forums i've heard about some green colored castrol which is supposedly fully synthetic and high quality yet cheap, but i have no solid info.
i run amsoil 10w40 -- $6.15 a quart at the local parts jobber. next time i'm going to order a case, as it's around $60 for 12 quarts.
Old May 24, 2005 | 09:10 PM
ianshoots's Avatar
The deal with synthetic is you pay up front, but then thats it. If you use Amsoi they suggest one oil change a year (with a filter change in the middle). Sounds crazy but a pile of folks do it that way (my bad self included).
Hard to get cheap and good at the same time.
Old May 25, 2005 | 12:50 AM
BCtoyota's Avatar
With an older 22re engine i would use 20w50 in the summer heat. That goes for most of the older class 4 cyl motors. I would say from 1985 to 1995. Yes i am way off topic.
Old May 25, 2005 | 11:06 AM
HaveBlue's Avatar
Mobil1 Clean 7500 blend - $2.20 @ Sprawl Mart
Old May 25, 2005 | 11:12 AM
Mudfreak's Avatar
cheap synthetic is basically an oxymoron haha.
Besides, I personally dont think its worth it unless automaker says use it.
Old May 25, 2005 | 12:01 PM
CynicX's Avatar
I find Mobil 1 pretty cheap at wal-mart...well as cheap as I've seen it...like 3-4 dollars...If you can find that big jug they have from time to time its even cheaper...
Old May 25, 2005 | 03:33 PM
95ToyotaPU007's Avatar
i heard good things about the Castrol synthetic mentioned above. its affordably priced at wally-world.
been using the quaker state semi-synthetic for the past 290,000 miles. so far so good.
Old May 25, 2005 | 03:36 PM
HaveBlue's Avatar
I've had good results with Castrol Syntec. Most notably in the '83. I gained 1 MPG.
Old May 26, 2005 | 08:19 AM
mastacox's Avatar
I use Valvoline Synthetic blend (only $2.50 a quart) and Purolator Pure One Oil Filter (about $5). Seems to work quite well.
Old May 26, 2005 | 05:23 PM
X-AWDriver's Avatar
The most I've seen Mobile 1 around here is $4.99/quart but I usually buy a case at Target or Costco and I usually pay about $23 a case.
Old May 27, 2005 | 02:46 PM
rugerm44's Avatar
There is an active law suit against castrol because the full synthetic oil has a petroleum base.I used it for years also.They will not get another dime from me.
bigjstang
Jun 2, 2025 03:56 PM
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
adammtb
Jul 27, 2015 11:57 AM
Coreyr384
Jul 10, 2015 11:13 AM
