Moaning
Old Jan 4, 2005 | 05:54 PM
payyourtoll's Avatar
it's AT, thanks for the info. It gives me something new to look into..
Old Jan 5, 2005 | 02:27 AM
Slowrunner's Avatar
Yes mine moans too @ 1800 rpm. I think its the fan clutch. Only does this when cold and only @ 1800 rpm. It does matter how fast i,m going , if I,m at 1800 rpm she moans untill shes at operating temperature.
Old Mar 9, 2005 | 12:40 PM
BUMPing this for any new ideas/help?
The noise is still here, and I just did:
tranny flush
coolant flush
new timing belt and other belts (V, alt, ac)
oil change + oil filter + lube
air filter, fuel filter
new pcv valve
and triple dose of seafoam to get things cleaned out a bit.
The moaning is still there and under the same conditions.
Hot or cold, doesn't matter.
Off the gas - no moaning
on the gas lightly at low rpm - moans badly
on the gas hard - no moaning.
please please please post any other ideas. I feel the shlt is going to hit the fam sooner or later.
thanks
Old Mar 9, 2005 | 01:13 PM
ugadawg95's Avatar
See this thread...I am having a similar issue:
U joints???
Pinion Angle with respect to the differential angle???
https://www.yotatech.com/forums/f2/ome-lift-installed-driveshaft-vibration-51725/
Old Mar 10, 2005 | 05:36 AM
  #25
U joints???
https://www.yotatech.com/forums/showthread.php?t=51725
Steven, lots of good info in that thread. I can't 100% relate to your problem though, since you have the vibration when OFF the gas, where as mine only makes the noise when ON the gas. Also the noise in my truck scares me more than the vibration. I feel we are sharing different symptoms of the same problem however.
This was posted in your thread:
Originally Posted by lv4runner
Stephen, I'm on the same page as you. This vibration/humming sound didn't start until I put the OME stuff on.
Same here, and I am glad someone used the word 'Humming' since I thought I was the only one with the noise. Humming, moaning, all what I hear in my rig.
I will start to track that thread you have started to see where it takes you.
arielb1
Oct 28, 2012 01:20 PM
dotcom
Jan 17, 2009 11:36 PM
brota4x4
Jan 6, 2009 09:35 AM
run4her
Nov 29, 2007 11:22 AM
celica
Sep 20, 2005 09:17 AM
