max tire size?
Old Aug 13, 2018 | 10:08 AM
Cwu3rdgen's Avatar
max tire size?
What's the max. tire size I can fit on a '96 sr5 4runner after installing the 3 inch bilstein suspension lift?
(this one --> https://bilsteinlifts.com/shop/toyota-4runner/1996-2002/lift-kits-96-02/3-lift-kit-with-bilstein-shocks-for-1996-2002-toyota-4runner/?gclid=CjwKCAjw2MTbBRASEiwAdYIpsfhOK_t8AEKr1DX-UOTdm5raWUzhR7ynuXufz9pbEjMWVMvmbqMQqBoCzdwQAvD_Bw E )
I'm currently running Dueler AT's in 265/75R16, and have no issues whatsoever (rubbing, etc) and on stock toyota wheels. In theory i would keep these wheels at least for the time being. What size tire should i look for?
Old Aug 13, 2018 | 11:58 AM
fierohink's Avatar
You should be able to fit a 285 75r16 or 305 70r16 which are 33" tires. You might get a little scrub on the 305 as it's nearly 2" wider than stock tire. I think a 315 75 r16, which is a 35" tire) is going scrub too much for enjoyment with stock wheels.
I don't have that set-up in front of me, but you're talking about a tire that is almost 5 inches wider than stock.
Old Aug 17, 2018 | 10:28 PM
Malcolm99's Avatar
You can't run a 35" tire without re-gearing and trimming, 33" x 12" will require a different offset rim or it will rub the upper control arm especially will sidebiters, most tire companies will advise you to go to a wider rim after you get to 33".
DeathCougar
Oct 12, 2021 03:59 AM
RustyRunner44
Oct 12, 2017 10:23 AM
Rock Slide
58
May 27, 2008 08:41 AM
Rock Slide
37
Apr 3, 2007 08:26 AM
