Manual to Auto on a 1998 4Runner?
I have a 98' 4Runner and It's a manual. I like it but sometimes I get annoyed with shifting all the time with those steep gears. Can I get a used auto transmission from like a junkyard and swap it in there?
It is alot easier to go Auto to manual than vice versa.
Originally Posted by SLC Punk
You will need:
Tranny
Flywheel
You may need to either get a new crankshaft or somehow drill a hole in your crankshaft for a pilot bearing.
Pedals
Slave Cyl
Clutch
Tranny
Flywheel
Pedals
Slave Cyl
Clutch
I would guess you are looking at $800-1500 for that depending on if you need to change cranks.
I've been thinking about this for some time, but I have a second genner. I know I can keep my wiring harness and ECU, but I've also though of getting a Celica with a 22re to do a major change on the truck. ECU, harness, gears and stuff. It'd be fun, but then I'd have to buy another truck to jack up and off-road so I don't get flamed
Originally Posted by BruceTS
All crankshafts are machined out for a pilot bearing
Jun 1, 2021 01:51 PM
1998, 4runner, 5speed, 98, 984runner47conversion, auto, automatic, conversion, ecu, harness, manual, swap, tacoma, transmission
