Manual to Auto on a 1998 4Runner?
I have a 98' 4Runner and It's a manual. I like it but sometimes I get annoyed with shifting all the time with those steep gears. Can I get a used auto transmission from like a junkyard and swap it in there?
i want a manual and i have a 98, we should swap! where are u located?
It is alot easier to go Auto to manual than vice versa. |
so if i wanted to go manual, i would need the tranny, ecu and wiring harness?
No, its only if you go from a manual to auto you would need the ECU
so i would need the tranny and the harnesses?
You will need:
Tranny Flywheel You may need to either get a new crankshaft or somehow drill a hole in your crankshaft for a pilot bearing. Pedals Slave Cyl Clutch |
i wonder if anyone here has done this to a 3rd gen? someone please chime in...
any idea of cost?? |
Originally Posted by SLC Punk
You will need:
Tranny Flywheel You may need to either get a new crankshaft or somehow drill a hole in your crankshaft for a pilot bearing. Pedals Slave Cyl Clutch I would guess you are looking at $800-1500 for that depending on if you need to change cranks. |
yeah i am interested in this as well. my tranny just went out and i hate having an automatic. looking into swapping a manual in there
I've been thinking about this for some time, but I have a second genner. I know I can keep my wiring harness and ECU, but I've also though of getting a Celica with a 22re to do a major change on the truck. ECU, harness, gears and stuff. It'd be fun, but then I'd have to buy another truck to jack up and off-road so I don't get flamed :hillbill:
Originally Posted by BruceTS
All crankshafts are machined out for a pilot bearing
