Made it 10K after the "strawberry mikshake"..now the tranny is done!
Good to hear. I just had the milkshake on Saturday, drained everything and pickup up/installed radiator yesterday, and will try to get the flushing finished today. I was planning to flush with around 30 qt, but it is good to know that you had to use closer to 40 qt before getting perfect fluid back out. ATF doesn't seem expensive for just drain/fill, but when doing 30 - 40 qt flush it starts to burn holes in your wallet.
Yeah, I probably could've used a little less but I was crazy picky about how clean it was and actually made a total of 3 trips buying more ATF until I was happy. If I saw anything other that crystal clear red I kept pumping it through. Shifting through all gears several times helped squeeze out the pockets of shake that were hiding too.
Ya, forgot to mention the part about shifting thru the gears too....
The thing I was worried about was the dirt in the water.... not the actual water itself. I have swamped this auto tranny at least 3 times that I can remember, and a good flush did the trick. Now I have hoses on the breathers on the diffs and tranny running up to the engine bay....shoulda done that to b
egin with.
egin with.
couple of quesitons, you said you removed the hoses? So I am understanding correctly, you just put the output hose into a large bucket and the intake hose for the tranny into the container for the new fluid? I take it then the tranny will pull the new fluid in on its own? Never done a tranny flush, always had it done but mine needs a good flush and if I'm gonna add these coolers (which will need to be flushed too) I was thinking this may be the best way to do both instead of trying to get the new (old) coolers solvent flushed first then flush the tranny. Might save me some time and effort/expense?
I won't be recovering from the Strawberry Milkshake so how much tranny fluid should I look at using to flush the system and new coolers myself? I understand about shifting through the gears so I just want to be sure I get the coolers flushed really well too. Ford ATF doesn't play well with Toyota transmissions
Any other suggestions?
I can't see there being enough suction to pull the new ATF in...
maybe if you had the bucket up higher than the tranny and gravity was helping.
Pretty sure you'll have to pour it in the dip stick tube.
#25
absolutely right.... I would do about a quart or so at a time, then shut the truck off and fill...then repeat, over and over again...lol
#26
Mine milkshaked around 65k about 2yrs ago and I replaced the rad and flushed everything silly (ran about 10 gal of trans fluid through it until it was perfect) and I'm at 101k now and still good for the most part (only a slight shift hesitation now when cold).
I figured that I could flush it myself and be sure that it was clean vs. a garage - I just ran it with the lines off - output to a bucket and input was in a fresh jug of fluid. Then I dropped the pan and cleaned it and changed the filter.
I didn't bother with Lucas or any additive either, just fresh fluid when refilling it - and it did take pretty much full fluid spec when I did.
It's worth a shot - $100 vs $1k+. For your nasty case I'd Lucas it too.
#27
#28
Ok, I need some help. I just bought a 97 4runner, with 137k miles.. 3.4, 4spd auto.. it runs great. I checked for a cooler, and it looks like the two lines just run from the Tranny to the Radiator.. not a separate auxiliary cooler. Is the Milky effect coming from this combo? I can take care of it if so, I was originally under the impression this was on the Tow Package models only.
oh, btw.. I don't have the Strawberry effect, just trying to prevent it. Thanks for the Post for us N00BS
#29
#30
#31
10-4 thanks. Will get it changed as soon as I can decide on the replacements. Probably next week sometime.
#32
BigBallsMcFalls, I think my luck had to do with it being so low in mileage and the prior owner being very good with maintenance. Especially when you consider the fact that I had to keep driving it shaked until the rad came and I had the weekend to work on it. I just kept jugs of ATF and would fill it before going to work and again to drive home (~20 miles each way for 3 days). Afterward I realized I should have done a bypass on the cooler but maybe filling it fresh 2x a day actually helped....
ox735
10
Aug 28, 2015 07:28 PM
tinigunner11
Aug 14, 2015 01:19 PM
Iceman4193
Jul 15, 2015 04:48 PM
