Made it 10K after the "strawberry mikshake"..now the tranny is done!
Old May 25, 2010 | 06:35 AM
zeik's Avatar
Originally Posted by mooseT
Good to hear. I just had the milkshake on Saturday, drained everything and pickup up/installed radiator yesterday, and will try to get the flushing finished today. I was planning to flush with around 30 qt, but it is good to know that you had to use closer to 40 qt before getting perfect fluid back out. ATF doesn't seem expensive for just drain/fill, but when doing 30 - 40 qt flush it starts to burn holes in your wallet.
Yeah, I probably could've used a little less but I was crazy picky about how clean it was and actually made a total of 3 trips buying more ATF until I was happy. If I saw anything other that crystal clear red I kept pumping it through. Shifting through all gears several times helped squeeze out the pockets of shake that were hiding too.
Old May 25, 2010 | 06:43 AM
Team420's Avatar
Ya, forgot to mention the part about shifting thru the gears too....
The thing I was worried about was the dirt in the water.... not the actual water itself. I have swamped this auto tranny at least 3 times that I can remember, and a good flush did the trick. Now I have hoses on the breathers on the diffs and tranny running up to the engine bay....shoulda done that to b
egin with.
Old May 25, 2010 | 10:11 AM
Ritzy4Runner's Avatar
Originally Posted by zeik
I figured that I could flush it myself and be sure that it was clean vs. a garage - I just ran it with the lines off - output to a bucket and input was in a fresh jug of fluid. Then I dropped the pan and cleaned it and changed the filter.
I'm trying to do a "prevent" on mine right now and using two tranny coolers from early '90 Ford Explorer's. Decided on using them vice aftermarket as they are alot more heavy duty and the construction is really solid.
couple of quesitons, you said you removed the hoses? So I am understanding correctly, you just put the output hose into a large bucket and the intake hose for the tranny into the container for the new fluid? I take it then the tranny will pull the new fluid in on its own? Never done a tranny flush, always had it done but mine needs a good flush and if I'm gonna add these coolers (which will need to be flushed too) I was thinking this may be the best way to do both instead of trying to get the new (old) coolers solvent flushed first then flush the tranny. Might save me some time and effort/expense?
I won't be recovering from the Strawberry Milkshake so how much tranny fluid should I look at using to flush the system and new coolers myself? I understand about shifting through the gears so I just want to be sure I get the coolers flushed really well too. Ford ATF doesn't play well with Toyota transmissions Any other suggestions?
Old May 25, 2010 | 10:35 AM
mt_goat's Avatar
I can't see there being enough suction to pull the new ATF in... maybe if you had the bucket up higher than the tranny and gravity was helping. Pretty sure you'll have to pour it in the dip stick tube.
Old May 25, 2010 | 12:24 PM
  #25
Team420's Avatar
absolutely right.... I would do about a quart or so at a time, then shut the truck off and fill...then repeat, over and over again...lol
Old May 25, 2010 | 12:34 PM
  #26
BigBallsMcFalls's Avatar
Mine milkshaked around 65k about 2yrs ago and I replaced the rad and flushed everything silly (ran about 10 gal of trans fluid through it until it was perfect) and I'm at 101k now and still good for the most part (only a slight shift hesitation now when cold).
I didn't bother with Lucas or any additive either, just fresh fluid when refilling it - and it did take pretty much full fluid spec when I did.
It's worth a shot - $100 vs $1k+. For your nasty case I'd Lucas it too.
man I am paranoid about mine lasting, but your results look ok. I guess it is a total crapshoot. I had mine flushed a metric boatload. works great now. hope it stays that way. i bet a lot depends on if you kept up with normal ATF service intervals prior to the milkshake
Old May 25, 2010 | 02:17 PM
  #27
This is exactly the reason I come here to ask these kind of questions as the post before by Zeik made it sound like that was how you would do it.
So to do this correctly you don't do what he said? Just trying to figure out the best and quickest way to do this.
Old May 25, 2010 | 03:48 PM
  #28
samster0077's Avatar
Ok, I need some help. I just bought a 97 4runner, with 137k miles.. 3.4, 4spd auto.. it runs great. I checked for a cooler, and it looks like the two lines just run from the Tranny to the Radiator.. not a separate auxiliary cooler. Is the Milky effect coming from this combo? I can take care of it if so, I was originally under the impression this was on the Tow Package models only.
oh, btw.. I don't have the Strawberry effect, just trying to prevent it. Thanks for the Post for us N00BS
Old May 25, 2010 | 06:08 PM
  #29
mt_goat's Avatar
Just follow this DIY write-up: http://home.centurytel.net/stevenjac...sh/tranny.html
Old May 26, 2010 | 02:56 AM
  #30
mooseT's Avatar
Yes, that is exactly the setup that has the problem (like mine). The milkshake seems to be very common right around 140k miles, so you should probably get this fixed asap. The longer you wait, the more at risk you're going to be.
Old May 26, 2010 | 04:37 AM
  #31
10-4 thanks. Will get it changed as soon as I can decide on the replacements. Probably next week sometime.
Old May 26, 2010 | 05:54 AM
  #32
zeik's Avatar
Ritzy, I'd follow the writeup that mt_goat posted since you haven't milkshaked yet. Mine shaked so I didn't want to hook up a new rad for the flush. It's been over two years since I did mine so it's a little fuzzy (drank and partied a lot since then) but I do recall having my input in a fresh jug but I think I did help it along by filling from the dipstick too.
BigBallsMcFalls, I think my luck had to do with it being so low in mileage and the prior owner being very good with maintenance. Especially when you consider the fact that I had to keep driving it shaked until the rad came and I had the weekend to work on it. I just kept jugs of ATF and would fill it before going to work and again to drive home (~20 miles each way for 3 days). Afterward I realized I should have done a bypass on the cooler but maybe filling it fresh 2x a day actually helped....
ox735
10
Aug 28, 2015 07:28 PM
tinigunner11
Aug 14, 2015 01:19 PM
yourrealdad
Jul 21, 2015 11:13 AM
Iceman4193
Jul 15, 2015 04:48 PM
