Low heat
Old Dec 29, 2004 | 05:31 PM
84pickup's Avatar
Low heat
I'm not getting much heat from my 84 pickup. Coolant level, thermostat, heater core, anything else? Suggestions?
Old Dec 29, 2004 | 06:13 PM
86toyota's Avatar
Heater control valve stuck, clogged rad., only other options.
replace thermostat first, cheapest options first. Older toys didn't have the greatest heat anyways(at least mine). heater core next.
Old Dec 29, 2004 | 06:24 PM
84pickup's Avatar
I'll try the thermostat, thanks.
Old Dec 29, 2004 | 08:49 PM
Yoda's Avatar
There is a cable that runs to the bottom of the heater case (pass side). It sometimes gets kicked loose on my kids truck.......then no heat
Old Dec 29, 2004 | 10:15 PM
mikedog's Avatar
My old '88 has nice toasty heat even with a 180* stat. It's gonna be cold though. It's getting down into the lower 40's tonight. I better go turn that heater up. Brrrrrr.
84pickup,
Yeah, try the thermostat first. If it's not that, then check the cable leading to the flapper door in the interior and check the one on the heater valve inside the engine compartment. I bet it's probably one of the control cables.
Old Dec 29, 2004 | 10:59 PM
Lt. Dan's Avatar
My heater controll valve was frozen half open, and the cable had jumped off the back of the cotroll lever. Pulled a used valve off a junked yota, reconnected the cable and violla, heat! I was only getting a little heat. Ya never know till you tear into it. Good luck!
Sleaker
Aug 26, 2020 06:03 AM
viesail
Aug 17, 2015 08:39 PM
dropzone
Aug 11, 2015 05:16 PM
jjrbus
Jul 19, 2015 02:06 PM
Coreyr384
Jul 10, 2015 11:13 AM
