Looking for t3/t4 turbo info for 2.7 or S. African S/C
Old Apr 25, 2004 | 05:52 PM
baileymoto's Avatar
not somethign i really want to do but id enjoy reading up on the t3/t4 turbo and/or the imported supercharger for the 2.7 made by some south african company. apparently TRD now offers the S/C for the 2.7 but uses a smaller blower, no ecu mods and no fuel mods.
Old Apr 25, 2004 | 07:34 PM
trangk's Avatar
What do you want to know about the t3/t4?
I run a Garrett T3/T04E (.48/.60 50 Trim) and love it on the 3RZ Had a .63/.60 before and that ran nice also, but a bit laggier than the .48 obviously.
Old Apr 25, 2004 | 07:36 PM
baileymoto's Avatar
did you custom fabricate the entire turbo setup? what are you using for ecu/fuel management?
Old Apr 26, 2004 | 02:37 PM
trangk's Avatar
The turbo setup was a complete custom setup. South Florida Performance (SFP) did the tubular manifold, and a friend and I did all of the intercooler piping/downpipe/etc. Fuel setup is 550cc injectors managed by a Greddy e-manage system. Old setup was a Vortech 6:1 FMU with the Greddy.
Old Apr 26, 2004 | 02:41 PM
baileymoto's Avatar
what do you estimate the entire setup costing you?
Old Apr 26, 2004 | 02:51 PM
Nolan's Avatar
there is also this one...
http://www.lcengineering.com/TurboKits.htm
Old Apr 26, 2004 | 08:25 PM
trangk's Avatar
Here's my parts list/cost. Also included a list of optional things that I added.
549.00 ... T3/T04E 50 Trim w/.48 A/R turbine
650.00 ... SFP tubular manifold
239.00 ... TiAL 38MM wastegate
212.00 ... Blitz DD Super Sound BOV
250.00 ... Spearco intercooler core
75.00 ... Greddy Airinx Air filter
120.00 ... Walbro HP 255LPH fuel pump
100.00 ... Mandrel bent pipes for intercooler
45.00 ... -3AN SS oil feed line
25.00 ... -10AN SS oil return line
24.00 ... -10AN 45 degree fitting
11.00 ... -10AN straight fitting
300.00 ... Greddy eManage
100.00 ... Vortech 6:1 FMU
300.00 ... RC 550CC high imp. injectors
75.00 ... SARD Fuel Pressure regulator
50.00 ... Silicon couplers
50.00 ... T-bolt hose clamps
15.00 ... Misc screws/vacuum lines/etc
Total ... 2815.00 (with FMU)
... 3090.00 (with 550cc injectors)
90.00 ... Blitz Turbo Timer w/PHW boost gauge
150.00 ... Greddy PHW EGT gauge
250.00 ... Greddy PHW Oil Pressure gauge
250.00 ... Greddy ProfecB (specII) boost ctrl
75.00 ... Greddy oil catch can
35.00 ... Dynomax 2.5" in/out muffler
75.00 ... o2 simulator for test pipe
50.00 ... Heat wrap
Total .... 975.00
Old Aug 26, 2004 | 09:56 PM
SpecializedBrder's Avatar
Can we get some pics?
Old Aug 31, 2004 | 09:18 PM
kevin444's Avatar
droool
Old Sep 1, 2004 | 07:31 AM
ETN4runner's Avatar
www.benzboy.com
this guy makes turbo manifolds for tacos. I think they run 400 or 450. After that, buy whatever turbo you want and get someone to do the pipe for you.
Old Sep 1, 2004 | 09:43 AM
havic's Avatar
How much hp are you getting out of that 4cyl?
Old Sep 1, 2004 | 11:49 AM
Bumpin' Yota's Avatar
Finally someone with turbo charging experience with yotas...
That is T3 housing holding the T04E-50 wheel? Could you walk me through the process of selecting the proper compressor from the compressor maps?
For the 4.0L v6 that toyota has I keep coming up with a T3-60 being the best compressor wheel looking at flow rates. A speed shop recommended a T4 with T04E-60 compressor wheel....
Any problems with your setup thus far?
last ? - the 3RZ is the 2.7L turboed 4 cyl?
Old Sep 1, 2004 | 08:18 PM
trangk's Avatar
wow this is an old thread
the t3/t4 means it's a t3 exhaust housing (smaller housing for quicker spool) with a t4 compressor housing (larger housing for greater top end). it's a compromise between a straight t3 and a straight t4 in terms of spool time/power.
to find the right size turbo, figure out how much boost you want to run and at what rpm you want to reach that boost level. then calculate the airflow at that rpm level. plot that on the compressor map (pressure is the y-axis, cfm is the x-axis) and see where it lies on the map. the goal is to try and get it in the "island" or ring where the turbo is most efficient. if you want more specific info, email or PM me. i can give you all the equations and such
no problems now. initially had some problems with exhaust leaks and running rich but that's all been fixed.
no the 3rz is the 2.7l n/a engine (2rz is the 2.4l). i don't think there's been a turbo 4cyl engine since the 22ret
runnermedic
Mar 14, 2015 09:45 AM
4X4 Evangelist
May 16, 2012 01:47 AM
R4G1NG_BU11
Apr 3, 2012 06:53 AM
gtrotter
Jan 12, 2009 05:09 PM
