looking at gear ratios
Old Dec 7, 2007 | 07:15 AM
98crazyrunnerJE's Avatar
I want to go to 305/7or16 tires I am currently running 285/75r16 with the stock gears, can I get anyway with running the 305 with the stock gears or will I have to change them out, if I have to change them out what kind of gears will I have to get installed thanks
Old Dec 7, 2007 | 07:28 AM
AxleIke's Avatar
You can certainly run that size with stock gears. Won't hurt anything. You may notice a drop in perceived power, as well as a drop in MPG. But you can run that way if you want.
Old Dec 7, 2007 | 07:37 AM
Rock Slide's Avatar
x2. If you are already comfortable with running 285/75s w/ stock gearing, then 305/70s are not going to make a big difference...in fact, it will be minimal at best. The 305/70 is very similar to the 285/75 in overall size.
Personally, I'd regear with 285/75s, but that is just me.
You can compare both tire sizes here: http://www.wickedbodies.net/Tire-Size-Calculator.htm.
Granted, which ever brand of tire you decide on, you may want to get the exact dimensions from the manufacturer of each. Reason being, every 305/70 for example, is not exactly the same size as another.
reply
If I was to run the stock gears how much would it hurt power and gas
Old Dec 7, 2007 | 07:50 AM
Rock Slide's Avatar
I would assume, just as much as the 285s do now + a little more. Again, the sidewall height, tire height and tire circumference is almost the exact same between both tires (by comparing them to the website I listed above). It's the section width that becomes greater. It goes from 11.22 to 12.01 inches. Therefore, it's not a huge jump up in tire sizes. You should see a decrease in mpgs and pwr, but I do not foresee either of them greatly decreasing from what you are already experiencing.
EDIT: Exactly how much would it hurt pwr & mpg, I can't say. You want know exact figures until you do the swap. Wish I could be of more help
Old Dec 7, 2007 | 09:21 AM
BajaRunner's Avatar
Stock gears with black steelies and 35's = loss of acceleration and braking. MPG is about 18+ on hwy and 15 in town.
Old Dec 7, 2007 | 09:31 AM
onesojourner's Avatar
lots of gears came stock what do you have in your truck?
http://intercotire.com/site63.php
Old Dec 7, 2007 | 09:56 AM
d0ubledown's Avatar
305's and 285's are basically the same height. the 305's being just slightly wider...so you should barely notice a difference if any at all...
RatOmeter
Oct 22, 2015 03:17 PM
norcal98
Aug 10, 2015 06:20 AM
wolfpackfan33
Aug 2, 2015 03:36 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
