looking for a 200amp alternator?
Old Dec 31, 2003 | 07:11 PM
Waterboy's Avatar
Originally posted by amusement
If someone has a chance, could they explain the need for the extra battery wired in serial? Thanks.
He doesn't need an extra battery in series he needs it in parallel. I was just being picky at a typo.
Old Dec 31, 2003 | 07:24 PM
BruceTS's Avatar
If you read his post, even though he says series. he meant parallel. He's using the term series as adding a second battery to the system. A common mistake that people make.......
Old Dec 31, 2003 | 10:21 PM
ldivinag's Avatar
use 3 batts in serial to do some mild welding. 36 volts was like the magic number, i remember reading from a mag.
2 batts with 24 volts is like the minimum.
Old Jan 1, 2004 | 09:12 AM
decepticon's Avatar
yes you are right parallel. And as for this hand dcab you daym straight this is a powerful hand. This hand held oon to the back of my truck and prevent it from fallin into the deeap and dark ditch
shooter86314
Jan 7, 2016 07:05 AM
Chicken12
Oct 14, 2015 03:54 PM
fountain
Sep 28, 2015 03:04 AM
SCZIG
Sep 20, 2015 09:00 AM
scheuvront1993
Sep 17, 2015 06:17 PM
