Lightforce Lights Install Time?
Old Jan 26, 2005 | 02:10 PM
Scofco's Avatar
I was down at a dealer of Lightforce today at work, so I thought I'd ask what their rate for installing some Lightforces would be out of curiosity.
They quoted me at 5 hours @ $70/hr!
You have got to be kidding me!
Anyone that has had a shop install their lights, what was the bill for the installation? I plan on doing mine myself anyways, especially now.
Old Jan 26, 2005 | 02:22 PM
dibble9012's Avatar
I would definetely do it yourself, that way, you know exactly whats going on under your hood, then if down the road, something gets fried, you know exactly where everything is. Id never trust my truck to some install shop, they get lazy when they do the installs day in and day out, shortcuts here and there can hinder performance. At least that was my experience.
Old Jan 26, 2005 | 02:31 PM
calrockx's Avatar
skyrat here helped me install mine. he's good with that electrical sorta stuff, and nice enough to help me install mine, the 140s then the 170s. with proper instructions i'm sure you can do it tho, even if it does take longer than a shop would. it shouldn't take 5 hours, no matter what you got.
which ones did you get?
Old Jan 26, 2005 | 02:32 PM
Scofco's Avatar
Didn't answer my question
I was just wondering if it really took an install shop 5 hours?
I could do it myself in under 5 hours.
Seems odd that the installation price costs more than the lights themselves.
Old Jan 26, 2005 | 02:33 PM
Scofco's Avatar
I'm going with the 240 Blitzs
My dad was blown away with how bright they are.
Old Jan 26, 2005 | 03:11 PM
Good Times's Avatar
I just picked up the 240 xgt's It's really really bright!! Well I can only comment on only one working as one of the wiring loom for the 240 was missing They're suppose to be reshipping it so I won't know what 2 lights would be like.
All I gotta say 1 light was definitely ALOT.
Installation took 1 hr? Definitely a piece of cake.
Biff (Victor) just installed 240 Blitz's on his 80 as well last weekend. The installation for his wiring was abit confusing as he used Slee's wiring harness but none the less it was pretty easy.
Old Jan 26, 2005 | 03:14 PM
jimbo74's Avatar
jsut for time reference, my friend can drop the tranny and reinstal the spare on his racecar by himself in under half an hour in the pits.....
Old Jan 26, 2005 | 03:28 PM
GodwinAustin's Avatar
Scofo - the wiring is a piece of cake...5 hrs is ridiculous - shouldnt take longer than an hour.
Old Jan 26, 2005 | 03:48 PM
midiwall's Avatar
Ditto. I think it took me longer to figure out where to put mine and get the hole drilled than to actually wire them.
Given that you have everything out and ready (switch/place to put it, relay/place to put it, wire, soldering iron (or buttend crimps), heat shrink, fish wire to get through the firewall...) then you're looking at less than 2 hours since you're be going slow. Once you've done it, you could do it again in an hour.
Old Jan 26, 2005 | 03:52 PM
4RunnerKid's Avatar
Definitely do it yourself. Installing aux lights is a breeze. Well, usually... Where are you mounting them Scofco?
Old Jan 26, 2005 | 04:05 PM
Darx's Avatar
It took me an hour to do my Hella Black Magics. Good directions and the whole wirining mess is already taken care of for me, all harnessed up. All I had to do was follow directions and plug this here that there and find my bright postive wire for a scotchlock.
You can do it yourself easy. Sounds like lightforces come in a harness as well? I'm no mechanical/electrical guy at all so if I can do it you can.
Old Jan 26, 2005 | 04:06 PM
Brendan's Avatar
5 hours?!?! Are you sure you weren't being quoted for a SAS? If you know exactly where everything is being hooked up to, you should be able to do it in a half hour.
Old Jan 26, 2005 | 07:13 PM
ranma21's Avatar
Reas assure it won take more than an hour. I just installed mine today, it is a piece of cake. Is better for you to DIY so that you know how to deal with it when things go wrong!! Good luck
Old Jan 27, 2005 | 10:33 AM
boogyman's Avatar
Talking
Ditto what everyone else said.. do it yourself, just follow the directions. Basic circuitry: ground->light->power. add a switch/fuse in there, doesn't matter which side, typically power. To add a relay, basically you have 2 circuits linking together like so:
ground->relay->switch->power and ground->light->switch(the relay)->power.
note that the relay in the first circuit is also the switch in the second circuit (the relay activates the second circuit).
hope this helps,
Russell
Old Jan 27, 2005 | 10:42 AM
Ducky's Avatar
Shouldn't be hard, the hardest part for me was wiring my 4 on my roof =) That was fun...
Old Jan 27, 2005 | 10:52 AM
bamachem's Avatar
1 hour tops.
Don't give them your business when buying the lights either. Someone who quotes $350 to install some lights is nothing but a CROOK, plain and simple.
Old Jan 27, 2005 | 02:19 PM
Scofco's Avatar
It was the Ford Dealership that quoted me. Go figure.
Old Jan 27, 2005 | 02:29 PM
Biff's Avatar
I would never pay $350 to install these, do it yourself, Goodtimes(Lance) helped me install mine. The wiring is pretty straight forward if you use a standard wiring harness. In my case I used the Slee harness which ended up taking me a little longer but in the end it worked out. One thing I did find out is that the 240's suck down alot of juice, my poor little autozone battery was nailed, had to get an Optima yellow top to compensate.
Old Jan 27, 2005 | 06:38 PM
AKTaco's Avatar
I had a local specialty shop install mine, as I had them put in a Billet grill and mount the lights behind the grill... less rock impact worries, no getting ripped off the front end in a parking lot worries, and much cleaner looking, imho.
It took about three hours total, and I think 2.5 of that was with us all standing around scratching our heads trying to figure out how to cut out the original grill, yet keep as much structural integrity as possible. Also, I had to go exchange the 170's for 140's so they would fit in the gap without having to relocate the radiator. There is just barely a 1/2" gap between the front of the lights and the grill with the little one.
It was a couple of years ago, but I think they charged me $150 for the install, including the grill mod.
Old Jan 27, 2005 | 09:04 PM
Brendan's Avatar
http://www.alphaaccessories.com/imag...hts/atough.mpg
i don't think you have to worry much about rocks doing any damage to these bad boys. cannonballs maybe...
