lifting the yota
Old Feb 9, 2003 | 12:02 PM
yotafool's Avatar
Arrow lifting the yota
jus wonderin which suspension lift kit people recommend for a 95 4runner with IFS and where to get it, ive heard about pro comp, skyjacker, trailmaster, and downey. Thanx
Old Feb 9, 2003 | 01:36 PM
Corey's Avatar
Co-Founder/Administrator
It kind of depends on how high you want to lift it, and what size tires you want to run.
There is a suspension round-up in progress linked from this page.
You can fit 33" tires on a 2nd gen 4Runner or truck of the same body style by cranking up the T bars up front, and in the back using some aftermarket coils such as Downey, OME, Performance, and also adding the Downey 1.5" spacer to the top of them.
And a 1" body lift and a little fender seam massaging in the front will yield room for 33" tires.
Check out the lift post in the frequent post forum.
But if you want to go bigger than 33s, then a IFS lift is probably what you are looking for.
Here's a post from Dan, and he is running 33s on his 2nd gen.
https://www.yotatech.com/forums/show...&threadid=4037
Here is what the spacers with the Downey coils look like.
https://www.yotatech.com/forums/show...&threadid=3974
This is a cheap way to run 33s without having to purchase an IFS lift kit.
Old Feb 9, 2003 | 01:53 PM
yotafool's Avatar
well, i would really like to put some 35" tires on my 4runner, ive also heard about getting maybe a 3" body lift with a 4" suspension lift, but would that cause any problems? thanx
Old Feb 9, 2003 | 02:05 PM
Skydigger's Avatar
Any body lift over an inch and you're looking for some extra work like shift linkages and steering wheel shaft etc...
Let us know what you come up with though. You could always do a SAS and put some leafs in the rear if you wanna go all out.
Warren
Old Feb 9, 2003 | 02:13 PM
jx94148's Avatar
With 35"s you will deffinatly want to re-gear your differentials if you don't want to totally kill your already sluggish accelation.
As stated with 2" or more of body lift you will have to fix your shifters, steering shaft, fuel filler neck and make sure you don't kink or over-extend your fuel lines. That's why I went with custom made 1.5 inch body lift.
Old Mar 16, 2003 | 09:45 PM
calrockx's Avatar
so there really is that much difference between 1.5 and 2'' lift? i was about to order a 2 inch lift, but then i changed my mind to a 1.5 inch. still need the steering column extender tho, right? any other reasons why 1.5 is better/no different than a 2?
Old Mar 17, 2003 | 08:08 AM
joshik's Avatar
im running 35s
i have 4" suspension lift. and 2" body lift, so im clearing pretty good. my rear sags now again after i put in the downey springs. but its all good, coz now i have lower center of gravity and i still have the travel.
but i did regear my diffs. they are at 456 so im running pretty good. im no dragster, but ish all good. saves me money in the long run... less speeding tickets!
Old Mar 18, 2003 | 04:32 PM
yotafool's Avatar
so if i was to get the 4 inch suspension lift, should i get Procomp, skyjacker, trailmaster, or downey? thanx
Old Mar 18, 2003 | 04:33 PM
yotafool's Avatar
or are most of the 4 inch suspension lifts the same
Old Mar 18, 2003 | 05:03 PM
yotafool's Avatar
lol, this is what i want my 4runner to look like
http://www.geocities.com/jakesta97/4...?1048038887494
does anybody know who owns this 4runner, i found it on this site http://www.hboss.net/cgi-bin/readers...&type=standard
Old Mar 18, 2003 | 05:23 PM
Firefyter-Emt's Avatar
A good compromise is a set of 32's.. (With 33's you only get 1/2" of height more) I just put a set on mine with 4:56 gears and a 5spd.. They stuff fully with out hitting front or rear, and the truck is still very streetable with out re-gearing (33 would need gears I think) Look for upcomming photos of the 32's
Old Mar 19, 2003 | 03:52 PM
cvlighthouse's Avatar
You should get the Procomp stage two becuse it has supports to the bumpstops from the blocks and also has rear supports behind the blocks to the main frame..
http://www.4wheelparts.com/product2....ss=PRO&cat=SUS
Get the downey idler arm gusset and the rancho HD add a leaf springs too...Good luck!
Old Mar 20, 2003 | 08:43 AM
yotafool's Avatar
would a 4:88 gear ratio be better for 35"s, and 5:13 or 5:29 would probably be a little over doing it right?
Old Mar 20, 2003 | 01:17 PM
Skydigger's Avatar
It's my understanding that most guys will go with 5.29 gearing for 35" tires. That will supposedly bring your odometer and RPMs in line with stock but I'd bet you would be just fine with 4.88s.
The bigger you go, the weaker the R&P.
Regards,
Warren
Old Mar 20, 2003 | 05:59 PM
Mudd Runna's Avatar
Any help
I don't know if this helps but when I was doing my research for my lift I decided to go with a full Superlift 4" suspension lift kit. Only because it was the only one that came with rear leaf springs. Here in Maine we can't use blocks in our suspension lifts, it's illegal. My 88 runner came with a 3" body lift so I had no choice in that one. But my local offroad shop was willing to work with me on what I wanted...He offered me a couple of choices. ProComp Stage II for the front, Superlift springs in the rear is what I should have gone with...but I went with the whole Superlift kit...I don't know call me anal...lol...So I've got a 3" body lift, 4" Superlift suspension lift, 33" SS TSL Radials running on stock 4.10 gears pushed by a 22RE and I know she won't blow a mustang off the line, but still accelerates rather well considering...I am going to regear to 4.88 though to regain some lost power...Hope this helps...
Jcrawl94
10
Oct 24, 2015 04:34 PM
Sep 4, 2015 09:27 AM
Sr5crawler
Jul 31, 2015 12:32 PM
coffey50
Jul 28, 2015 10:55 AM
