Lifted and 33's
Lifted and 33's
Just installed my Old Man Emu coils with 2 inch spacers, and put 33x10.5x15 BFG Mud terrian tires. Here' s some pics.
As far as the front suspension goes, I cut the upper bumpstops in half and cranked the torsion bars a little bit. The back is definitly higher than the front but I like it like that for when I load camping gear in the back or pull a 3500 pound boat. I really like the tires. Once I'm up to highway speeds (60 mph) you don't really notice the noise anymore. I'm not too fussy about the noise anyways, otherwise I would have bought street tires.
I didn't have an option with the Old man emu springs. They said this was the only kind. They're supposed to be 2.5 inches higher than stock, but after I installed them it was more like "stock" without the saggy rearend. So I went to the wreckers and got them to cut off two factory spring perches off another 4runner. Then I welded a 3" diameter x 2" inches tall pipe to the spring mounts. The whole unit then slips right over the spring mount on the truck. I works pretty good and look very stock. It's kind of like a frame extention of sorts.
I did not re gear yet. It is slower, but I can deal with it for now. The gas mileage didn't drop too much, but then again I'm not done my first tank yet.
Only problem I have now is it that I can't go wheeling right now cause of all the forest fires in British Colombia. All the backroads are closed and everything is very dry.
Mike.
Mike.
If you are only on the street with a swaybar connected, I would doubt they rub.
If you wheel it with the swaybar disconnected, that ought to rub like heck. My fender seam took some serious adjusting and a 1" bodylift to run 33x12.5's.
With manual hubs, my CV boot life has decreased compared with pre-manual hubs oddly enough.
It doesn't rub on the street at all, but I have not taken it off road yet. The truck is very tippy on the street though with the swaybay disconnected. I've had the truck on 3 wheels while accelerating hard on a sharp slow speed turn.
Mike.
Mike.
There is no way to run spacers with torsion bars...
justdifferentials
Sep 5, 2015 06:52 PM
joeynational
Sep 5, 2015 01:54 PM
