Levoc Shifter
Old Aug 27, 2003 | 06:33 AM
ugadawg95's Avatar
Levoc Shifter
I have seen some folks switching the stock T-Bone out for one of these. I need as much info as I can get on replacing mine with the Levoc. Anyone??? Thanks Yotatech!!!!! You guys rock!
Old Aug 27, 2003 | 11:44 AM
ugadawg95's Avatar
Anyone?
Old Aug 27, 2003 | 12:12 PM
ravencr's Avatar
I may be stupid, but what they heck are you talking about?
Chris
Old Aug 27, 2003 | 12:15 PM
ugadawg95's Avatar
Chris
Sorry...i thought these were pretty well known...Guess not
http://www.napolex.com/index2.html
I was thinking about getting the LV-453. I found them for $79.99 on another site. Thanks!
Old Aug 27, 2003 | 12:16 PM
ugadawg95's Avatar
try this one
www.naoplex.com/knobs.html
Old Aug 27, 2003 | 12:17 PM
ravencr's Avatar
Nice, but I don't have anyhelp for you. Sorry!
Chris
Old Aug 27, 2003 | 12:21 PM
ugadawg95's Avatar
Originally posted by saintsteve
try this one
dang i'm lysdexic
www.napolex.com/knobs.html
Old Aug 27, 2003 | 06:10 PM
DuB's Avatar
DuB
my roommate got the carbon fiber one as a present. I think the shifter is way too high though. if you could somehow chop the shifter down like an inch or two, it would be perfect.
Old Aug 27, 2003 | 07:38 PM
HaveBlue's Avatar
Those are COOL!
Will they fit a '96 with the original shifter (non T-type)?
Old Aug 27, 2003 | 10:43 PM
FirstToy's Avatar
man, those are some cool looking shift knobs on that page!
Old Aug 29, 2003 | 12:17 AM
butnut's Avatar
I installed one in my '99. It does sit a little high ( I had a chopped hurst stick in my old Datsun) but it's at a comfortable driving height. After I put it in, I thought about cutting it way down, I did'nt study the spring so I'm not sure if it's possible. I'd like to one day except I'm done messing with my Runner...into modding guitars now.
I used a butt (crimp) connector instead if the quick disconnect connector it came with...who's gonna take it on and off again? My T bone 'exploded' when I pulled it off, I knew there was no turning back. It helps to leave it in neutral when doing this switch so you have more room...can't shift once the T comes off. I had to retap one of the set screw holes, check your's before you install. You have to cut the OD wire, do it close to the base. If you can, see if it's possible to shorten the stick, it would look beter...good luck.
Old Aug 29, 2003 | 03:41 AM
ugadawg95's Avatar
Thanks for the info JB!! I am going to give it a try here in the next few days
Old Aug 29, 2003 | 09:33 AM
ugadawg95's Avatar
Ordered the shifter...I will post a write-up of the install and post it for those interested.
Old Aug 30, 2003 | 11:07 AM
HiLux_1990's Avatar
Not to hijack the thread or anything, but....
I was checking out the Levoc pedals and saw this:
Levoc Sports Pedals are made of 52s Aluminum and fits almost all passenger cars The HMP (High-grip Metal Pivot) provides comfortable and smooth controls in "Heel-and-Toe" and other high level driving techniques.
Does anyone know anything about such 'high level driving techniques'?
sounds quite interesting...
Old Aug 30, 2003 | 11:26 AM
wimpywade94's Avatar
uh...someone correct me if im wrong, and i dont know that much about the high level driving techniques, but if you come burning into a corner, and slam the brakes then try and accelerate after you get past the midway of your turn, you tend to have slower speeds then if you brake while keeping the revs up using the accelerator, then bomb out of the corner, and also you can slow down faster and make is alot smoother and better sounding when your compression brakeing using the gas pedal to keep the revs up in between downshifts.....
wade
Old Aug 30, 2003 | 01:52 PM
butnut's Avatar
No problemo. I'm not Jason B BTW, he made my mini-page for me and put up his logo...I am a big fan of his killer dash kits and klear lens. Good luck with the install, let me know if cutting the squared shft tube looks possible without affecting the guts in there...I may try it one day...I love chopping stuff! You'll love the way the new OD button has an electronic-click feel to it...
Old Aug 30, 2003 | 03:29 PM
mtnkid85's Avatar
I think Ill jsut stick w/ my B&M . http://www.imagestation.com/picture/...7/fb3bf5b0.jpg
I like them and they are only like 20 bux
mwisham
May 26, 2021 02:51 PM
punks_is_4x4
Feb 26, 2016 04:29 PM
irv
Sep 22, 2015 11:51 AM
briholt
Sep 20, 2015 10:26 PM
eggens
Sep 5, 2015 12:16 AM
