Kill switch
Old Aug 28, 2004 | 04:38 PM
desert whomper's Avatar
Kill switch
Hey guys, i need to put a kill switch on my truck soon, alot of cars at my work have been getting stolen. Should i make the switch kill the fuel pump or power to the whole truck? or is there other methods too?
Old Aug 28, 2004 | 07:17 PM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
You didn't mention what year your rig is, but one sure fire way is to pull the EFI fuse or wire a switch in that circuit. I'm sure there are other ways that won't reset the ECU.
Old Aug 28, 2004 | 09:04 PM
ebtide's Avatar
i'd kill the ignition wire. Less amps going through the dash. After my 4runner was stolen I was considering this too. Let us know how it goes!
Old Aug 28, 2004 | 09:39 PM
ok, im a lil confused now, should i kill the fuel pump or the ignition or the EFI, what the hell is the ECU and is it bad to reset. lol im a little new here
Old Aug 29, 2004 | 05:08 AM
HondaTec521's Avatar
I put toggle switches on my Honda's.Between the main relay and the fuel pump. The ECU is the "electronic control unit"or "engine control unit"or "the computor that controls the engine outputs"
I haven't done my runner ,yet.
Old Aug 29, 2004 | 06:30 AM
Rick F.'s Avatar
ok, ...and is it bad to reset. lol im a little new here
It's not bad to reset the ECU. The (minor) concern is that the ECU "learns" from various inputs while you drive and that it starts from scratch after you reset it. I've never had any problems after resetting mine, which usually is about once per 6 months when I have to clean my Master Airflow Sensor (MAF) after it gets contaminated from the oil in my Amsoil oiled air filter (which cause the Check Engine Light, CEL, to come on).
Now that I've started overloading you with acronyms, are you sorry you asked?
Old Aug 29, 2004 | 08:13 AM
haha no im not sorry, im happy. i need to learn this. thx for all the input
Old Aug 29, 2004 | 10:31 AM
MLesch's Avatar
most people put a switch on the starter, this site: http://www.the12volt.com/relays/page2.asp has a lot of info about starter interupts, if you dont have a car alarm than you will need to do the passive starter interupt.
Old Aug 29, 2004 | 04:58 PM
jb9237's Avatar
I'm going to have a "kill switch" installed in my 4runner this week. It's not actually a switch, but to start the car, you have to pull the headlamp-controller back (highbeam position) as you turn the key. Once the car has started, let go of the headlamp-controller (normal position) and off you go. It's a good theft deterrent cuz it's kinda hard to figure it out.
p.s...there are also other options instead of using the highbeam, you can also use things like the cigarette lighter has to be pushed in to start the car.
Old Aug 30, 2004 | 08:39 AM
96LtdYota's Avatar
I know how to steal your car now...
Old Aug 30, 2004 | 09:02 PM
how did u figure out how to do that our did a shop do it, that soudns pretty cool, i wanna try it.
Old Aug 30, 2004 | 10:05 PM
Foo Fighter's Avatar
LOL me too!
Old Aug 31, 2004 | 10:23 AM
bump, anyone know how to do it?
Old Aug 31, 2004 | 08:51 PM
jb9237's Avatar
I took it to a car alarm/security place and they charged me $50 to have that "special kill switch" put on. Since I'm electrically-challenged, I thought it was worth it to have a professional install it.
oops!
Old Sep 1, 2004 | 11:20 AM
X-AWDriver's Avatar
I vote for the fuel pump relay since that can't be defeated;no power,no gas.
Old Sep 1, 2004 | 11:29 AM
rimpainter.com's Avatar
We just pull the EFI fuse on our 12-second Accord EX. We don't want anyone stealing that bad boy.
kawazx636
Oct 6, 2021 03:03 PM
beltcutter
Sep 30, 2015 06:14 AM
PNW94Runner
Sep 29, 2015 02:55 PM
charlie_fong
Sep 27, 2015 10:06 PM
runnermedic
13
Sep 21, 2015 05:20 PM
