Kill Switch...
Old Feb 28, 2007 | 07:02 PM
  #41
midiwall's Avatar
Originally Posted by drguitarum2005
does anyone know how much current the + lead of the fuel pump draws? If I could just find a toggle that can handle that much DC current, thatd be much easier than using relays and other circuitry
The last thread that went though this I THINK spec'd the stock fuel pump at around 17amps. That's a lot of current for running wires into the cab (think "will generate heat on long trips"). A 30amp relay is about $8-9, and then you could even use a small mini toggle, or a reed (and a latching relay) or ....
Old Feb 28, 2007 | 07:21 PM
  #42
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
17 amps, doh. thatd be hard to find in a toggle switch. i could find a relay rated for the sure, but then i'd have current constantly being drawn one way or the other, which i dont want. i should look into your other suggestion...
irv
Sep 29, 2015 06:20 PM
83
18
Sep 21, 2015 06:15 PM
theBAYsic
Sep 16, 2015 05:21 AM
Papadeath
Sep 14, 2015 10:26 PM
ac7822
Sep 12, 2015 06:57 PM
