Interesting Brake issue.
Old Aug 27, 2008 | 06:46 PM
86tuning's Avatar
Originally Posted by twitchee2
the steering wheel doesnt shake but the pulsing is back.
Try pulling the handbrake while going 30-40mph and see if you can feel it pulsing. The handbrake actuates the rear brake via cable. Be careful, and make SURE you can release it.
No shake in steering = not front brakes.
Old Aug 27, 2008 | 10:43 PM
twitchee2's Avatar
the handbrake doesnt do much, i think i need to adjust my rear shoes, but i will definatly try it out.
Old Aug 29, 2008 | 10:53 AM
twitchee2's Avatar
anyone know what the difference is between those rotors?
Old Aug 29, 2008 | 11:08 AM
twitchee2's Avatar
Well i just looked and i do have a leaky ball joint on my drivers side. I do really know what to do about replacing it?
Old Aug 29, 2008 | 09:12 PM
  #25
Ron Helmuth's Avatar
ow twitchee this thread has gone all over the place.
NO I don't see any difference in those 2 Brembo rotors you linked us to- but one has thickness measurements and so on. I used Auto Parts WH earlier this year for mine-pretty sure they were the 25488 and wow I don't recall them being that much. Look around some more. They always got a coupon deal going. I was thinking they were more like $56.
111db that is most helpful your first two lines about towing. Twitchee as he says the Tundra upgrade is likely overkill if you are not towing and such.
111db I routinely advise folks against towing with their Runners-as you say you did it once and would not do it again. A wider track and longer wheelbase make a more stable braking platform things you can't change by much in the Runner.
Please explain the line about the "not since 1968". I have to admit I had not heard the "warp in a cold stream" for quite some time, is there some science here...?
Twitch I swore off the Pep Boys but don't they cover their stuff even this long?
If not consider it a cheap lesson and get a good combo of rotors and pads-I would guess your pads are likely fine but why mess with an unknown?
Start fresh and go Tundra if you really think you need to-lots of guys have done it. Gather up your parts-it's not necessary to go all new and I would venture a guess some other So Cal dudes can help you install it. I would if I were there.
Easy for me to work on other people's rides...
Old Aug 30, 2008 | 01:07 PM
  #26
twitchee2's Avatar
Well, i just adjusted my rear brakes a little and its much better, i can feel the warpage at slow speeds. just slight pulsing. I would like to do the tundra brakes, but all im towing is a jet ski. I can lock the fronts up with the stock brakes if i need to so i think im good. idk what im going to do.
JNapolitano
Nov 14, 2019 07:46 PM
okamikai
Apr 30, 2018 10:19 PM
Sep 4, 2015 09:27 AM
corey519
Aug 12, 2015 11:12 AM
