intake or ehaust?
Old Aug 20, 2005 | 05:20 PM
Nick Cuban's Avatar
Post intake or ehaust?
im putting a 3" sus. lift on my 01 tacoma and putting 285's on it instead od stock 265's. i want to get some more hp out of my truck to help with gas and making the power feel the same... should i get intake or ehaust? whichever you choose, pleae tell me which one youd get:brand size whatever. thanks
Old Aug 20, 2005 | 05:27 PM
HUTCHSTACO's Avatar
make your own intake that basically free, then you can do both. i would just add a magnaflow muffler and an exahust tip.
Old Aug 20, 2005 | 05:30 PM
Nick Cuban's Avatar
how might one make your own intake? and will the muffler and tip boost hp?
rocket's Avatar
Flowmaster 40 Series
Old Aug 20, 2005 | 06:14 PM
rockota's Avatar
Neither will give you enough power to make it "feel" the same as before. If you want it to feel the same, then it's time to regear...
Old Aug 20, 2005 | 07:28 PM
Nick Cuban's Avatar
regear? im only going 2 sizes up with the same rims... not worth the money to regear... well if i had the money it would be, but i dont
Old Aug 20, 2005 | 07:34 PM
X-AWDriver's Avatar
Deckplate mod ---->https://www.yotatech.com/~corey/tech.../deckplate.htm
This costs under $15 to do and it nets you the same 7-8whp as a $200+ K&N Filtercharger intake kit.
An exhaust realistically will give you a few ponies in the mid range (2.25" is ideal on the NA motor) but it ends up being a sound mod more than a performance mod with a good muffler.
Old Aug 26, 2005 | 11:23 AM
97Limited's Avatar
Hey Nick;
Go with the Deckplate Mod with a good performance filter, (cause you are gonna have to clean it more offen the usual because of the 4" hole you will be putting in!!!) Then my vote will always be for a Magnaflow muffler!!! Because they have NO BAFFLES so it's straight through design!!! They sound really good with the V6!! (nice and throaty)
Good Luck
Old Aug 26, 2005 | 07:52 PM
HUTCHSTACO's Avatar
you could also look into the intake silencer mod (isr)
kawazx636
Oct 6, 2021 03:03 PM
LittleUgly
15
Jan 2, 2020 01:30 PM
wberry85
May 17, 2016 05:45 PM
mreagen
Oct 5, 2015 04:27 PM
bradahman
Oct 1, 2015 09:24 AM
