installing locker NOW, need help.
Old Aug 4, 2005 | 06:06 PM
jayhackett03's Avatar
i'm have the 3rd member out and the ring gear off. how do i get that little pin out so i can get the big pin out?
Old Aug 5, 2005 | 08:18 AM
rngrchad's Avatar
You need a set pin punch. ACtually any punch will work. If I remember correct you shouldn't have to remove the whole set pin. I also believe the carrier that the set pin is in has a small flap of metal covering the setpin on one side, maybe both. Look for that and pry it up. I did and ended up breaking it clean off. I then had to mushroom the carrier on re-installation to prevent the setpin from coming out again. Does this make any sense? Anyways if your having trouble getting the setpins out make sure you try to go the other way with them. I really think they only come out one way, I figured that out after beeting the shi*t out of them. Good luck.
Old Aug 5, 2005 | 11:09 AM
leiniesred's Avatar
punch out the little pin
grind out the dented in part at the big end of the hole a little bit.
Use a punch to push the little pin out the hole. Now you can remove the ring gear if you haven't done so already and slip the big cross pin out of there. It sounds like you are working on a 4cyl diff and putting in a lockright or ez locker.
Old Aug 5, 2005 | 05:41 PM
4 cylinder diff, aussie locker. close. turns out i have an oddball 30 spline yoke and have to get the conversion yoke from PORC. i wish i had the normal 27 spline yoke. kinda gay i think.
Old Aug 5, 2005 | 05:47 PM
rngrchad's Avatar
Sheesh, what luck.
Old Aug 5, 2005 | 06:16 PM
Originally Posted by rngrchad
Sheesh, what luck.
yeah, no ÅÅÅÅ, i was so pissed when i figured it out. it's $71 to get it 2nd day overnighted to me, or whatever it's called. the part costs $39. i was pissed. now i can't drive my truck for another 4 days.
Old Aug 5, 2005 | 07:14 PM
BajaRunner's Avatar
Sounds like something that would happen to me... grr.
Old Aug 6, 2005 | 10:11 PM
anybody else heard of this oddball 30 spline yoke?
jerusry
Oct 19, 2015 05:28 PM
Daneums
Aug 20, 2015 05:36 AM
jaretstuff
Aug 4, 2015 02:08 PM
A2theK
Jul 12, 2015 10:46 AM
bryan34w
Jul 6, 2015 05:53 PM
