installed my Freeway Blasters today :)
Old May 14, 2005 | 09:56 PM
tgreathead's Avatar
Installed a High & Low Freeway Blaster today. Even though I pulled the battery connection I still had this sinking feeling that the horn would go off as I connected it (kinda like sticking a fork in the toaster after you unplug it).
I had one little problem. I was installing them in the parking lot of Pep Boys and got the driver side done no problem. The passenger side had a pipeline routed in front that made the bracket too long. I drove home and tried out the horn. Didn't really notice a difference but remembered it was only 1 of 2. Drilled a new hole in the bracket and chopped the top. Plugged them both in and WOW, I can't believe I lived all these years with all sorts of wimpy horns. Ain't nobody cuttin' me off now!!!
Old May 15, 2005 | 02:27 AM
Corey's Avatar
Co-Founder/Administrator
Welcome to the club
I dig my Freeway Blasters.
They command respect.
Old May 15, 2005 | 03:00 AM
Beartracker's Avatar
What does it sound like? Where do I get one? How much do they cost? How hard to install one on an 01 Tacoma ? Did I forget to ask you anything? Mike
Old May 15, 2005 | 03:41 AM
Corey's Avatar
I have a very old video in the Tech section of what the horns sound like.
Still have not got around to getting a better clip after all these years.
Old May 15, 2005 | 05:56 AM
Paul H.'s Avatar
Mike, most auto parts stores carry them. They cost around $12 each. Make sure you get a High and a Low frequency one.
Old May 15, 2005 | 07:58 AM
Scofco's Avatar
I have them, Rachel says they sound wimpy.
I do know it's her honking at me even when I'm not looking though. Definately has a unique sound. Congrats, now it's fun to honk at people again!
Old May 15, 2005 | 08:11 AM
tgreathead's Avatar
If you like I'll make a sound clip so you can hear the difference.
Seriously? Just pull over and ask her to drive one night and while she walks out front to switch with you lay on the horn. Then peel out screaming "Freeway Blasters B!†©H"
But then go back for her and appoligize
Old May 15, 2005 | 08:15 AM
kevin444's Avatar
The installation is too easy its practically plug and play no cutting wires or anythign on a 3rds gen.
Old May 15, 2005 | 08:16 AM
Scofco's Avatar
Rachel just thinks they're wimpy (so do I a little), because we are both used to hearing the air horn I use at work.
Old May 15, 2005 | 08:44 AM
tgreathead's Avatar
Did you have the same problem with the bracket? I remember hearing everyone say it was just plug and play but mine wouldn't fit without cutting down the bracket. Weird. Other than that, ya. I even left the stock horn 'clips' on and just crimped the blade connector so going back to stock will take mere seconds.
Old May 15, 2005 | 09:00 AM
If you have the time I would like to hear it. That would be great!. If it's louder than what I have it will help. These Tacoma horns are not great,Lol. Mike
Old May 15, 2005 | 09:03 AM
tgreathead's Avatar
I'll make a clip this afternoon. It's kinda hard to tell how loud it is relative to other noise. Any ideas on how to show the comparison?
Old May 15, 2005 | 09:26 AM
CynicX's Avatar
talk at normal volumn for a second at the same distance from the mic has the horn is....seems lke it would give us a good comparison from talking volumn....
Old May 15, 2005 | 10:32 AM
midiwall's Avatar
Air horns! There's my cue!
http://www.midiwall.com/4Runner/airhorns.html
There's a clip on there these days...
Old May 16, 2005 | 06:15 PM
tgreathead's Avatar
okay, I took some clips but the problem is the audio on my digicam adjusts dynamically so they don't sound nearly as loud as they are. Just listen to Corey's freeway blasters to hear the tone and imagine them a lot louder.
jashoeuh
Nov 18, 2024 08:08 AM
smthwsn357
May 1, 2024 07:28 AM
Scotto6591
Sep 1, 2015 03:24 PM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
anniesball
Jul 30, 2015 12:14 PM
