Installed deck plate truck won't start
Old Aug 5, 2004 | 08:23 PM
cobrahunter's Avatar
After putting the deck plate in the truck it won't start. I washed out the air box with water. I'm assuming that getting the Mas Flow Sensor didn't help. Anybody had this problem?
Old Aug 5, 2004 | 08:53 PM
Bob_98SR5's Avatar
you washed your MAF?
also, did you pull the EFI fuse? if so, plug it back in and try again.
bob
Old Aug 5, 2004 | 08:56 PM
kevin444's Avatar
did you make sure you plugged the cable back into the maf? make sure it snaps in
Old Aug 5, 2004 | 09:15 PM
bob
I did wash MAF. But I didn't pull the EFI fuse would that make a difrerence?
Old Aug 5, 2004 | 09:34 PM
BajaRunner's Avatar
Some of the writeups when dealing with your intake say to pull the EFI 15A fuse out helps reset the computer to get used to the new airflow... He was making sure you put it back in if you had pulled it out in the first place.
Sounds like you didnt, but, that wouldnt cause your engine not to start.
Let your MAF dry out over night. Unplug it and make sure its dry before starting it back up.
scary stuff...
Old Aug 6, 2004 | 12:17 AM
oly884's Avatar
Guest
Did you plug the connector to the MAF back in?
Old Aug 6, 2004 | 03:19 AM
Cebby's Avatar
Water and electronics/sensors is not a good combination. It's quite possible that the MAF is fried if you plugged it in and tried to fire it with it wet.
Old Aug 6, 2004 | 03:39 AM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
Originally Posted by cobrahunter
...I washed out the air box with water. I'm assuming that getting the Mas Flow Sensor didn't help...
I would give the MAF a shot of contact cleaner to drive off any moisture, pull the fuse again and doublecheck all the connections. You may try unplugging the MAF connector and giving it a shot of contact cleaner, too. I wouldn't hose down anything else under the hood or in the passenger compartment, for that matter...
Old Aug 6, 2004 | 04:22 AM
MODZILLA's Avatar
From: Bend, Oregon. 4mer Teufelhund, now a DoD Contractor
Does anyone know of a pin to pin ohm out procedure to see if he is still within specific resistance tolerances? Unless I'm way off base I'm thinking that sensor is just a coiled transducer circuit with a specific range of ohms that can be measure and checked for continuity. I also assume that it's possible to open up the maf and inspect it for moisture or allow it to dry if necessary.
Old Aug 6, 2004 | 05:48 AM
grams72's Avatar
Did you disconnect the air tube? If so make sure that all the clamps are tight. Mine will not run if I have an air leak
Old Aug 6, 2004 | 07:22 AM
MTL_4runner's Avatar
Most MAFs are just a hotwire setup so a simple resistanve check should work fine. I doubt just getting water on the sensor will kill it and even then the truck should start but just run crappy......my bet would be something else (make sure you plugged the MAF back in correctly if you did disconnect it).
Crazychris1871
Jun 27, 2016 10:38 AM
Jdgarrison
Oct 1, 2015 05:22 PM
newzingo
Jun 24, 2015 01:50 PM
88Toy
7
Jun 17, 2015 09:40 AM
