installed 3" BL
Old Dec 10, 2007 | 09:07 PM
4rx's Avatar
4rx
installed 3" BL
I installed 3" body lift a couples days ago.... *Nevermind, it turned out to be a busted CV* I'll post some pics of it on the weekend!
I have another question. The idle jumps just a little going from 700rpm to 800rpm every 30 seconds or so. That happens ever since I replaced MAF(5,000ish miles). I was thinking maybe time to clean throttle body? Is it normal?
Old Dec 10, 2007 | 09:37 PM
BajaRunner's Avatar
The clicking... where is it coming from? Front/Rear? Suspension? Frame? Engine? Wheels?
Old Dec 10, 2007 | 09:45 PM
4rx's Avatar
4rx
I thought it might be more helpful from people who have body lifts on it. They might have same problem. I think its more like clunking. not clicking. My 4Runner is still driveable but dont want to ignore it.
Old Dec 11, 2007 | 02:57 AM
Nate08's Avatar
So where is it coming from?
Old Dec 11, 2007 | 04:29 AM
waskillywabbit's Avatar
Did you trim all the zip ties? Something might be hitting one as it spins.
Only a couple things you mess with on the body lift and that is body mounts, radiator and steering extension. That is where I would look first (and the zip ties).
Old Dec 11, 2007 | 05:46 AM
Gerdo's Avatar
Is it, just by coincidence, the CV on the left? Is it the fan in the schroud?
As far as the RPMs go, I have seen that on mine before. I would reset your computer especialy if you didn't after the MAF. To do this just remove the negitive battery cable for a minute then reattach. Your 4runner may not run the best untill the computer "learns" all of it's settings. It shouldn't take long.
Old Dec 12, 2007 | 04:55 PM
4rx's Avatar
4rx
It turned out to be a busted CV.. thank you Gerdo
Old Dec 17, 2007 | 07:12 AM
Gerdo's Avatar
Glad you found the problem.
nvdesertrunner
May 11, 2020 08:18 PM
wwjr
Sep 7, 2015 09:27 AM
punks_is_4x4
Aug 21, 2015 01:35 PM
Esibnitsud
Jul 30, 2015 08:19 PM
