Increased Idle on 3.0
Old Oct 16, 2004 | 09:45 PM
Sludge's Avatar
I have noticed that past weeks that when the truck is warmed and idling in park the rpms where in the 800-1000 range normal for my rig is 700-800 rpms and now tonite after sitting at a drive thru window waiting for my food the idle was around 1250 in park. I found a few possible answers while doing a search. But i want to pick the brains of the ppl here a little bit more.
Old Oct 16, 2004 | 10:29 PM
AgRunner06's Avatar
I just found 3 vacuum leaks that contributed to my high idle. Also try cleaning the throttle body.
Old Oct 17, 2004 | 10:00 AM
Sludge's Avatar
I cleaned the TB last month but i will try doing that again.Maybe a seafoam treatment is in order. As far as checking for vacuum leaks whats the best way to find them
Old Oct 17, 2004 | 10:09 AM
superjoe83's Avatar
spray carb cleaner or brake clean around all of the vacuum hoses, and if the idle changes, you have a leak in that vicinity
and i think there was a thread here a few days ago where a guys idle was doing similar stuff like yours and it turned out to be either a bad or misadjusted TPS, i cant remember which one
Old Oct 17, 2004 | 04:58 PM
Bumpin' Yota's Avatar
hmmm interesting....
I cleaned my throttle body very carefully with a rag sprayed with TB cleaner only...
My hot idle went from about 700 to about 900 rpm idle...Cold warm up idle is 1200-1300 as expected.
Old Oct 17, 2004 | 06:21 PM
uxb101's Avatar
mine was doing the same thing and i cleaned the tb with tb cleaner couple days later my tps was shot had to change it costed $200 Canadian so watch where you spray that cleaner ,ive heard people taking the tps off then cleaning the tb i will next time i clean mine
Old Oct 17, 2004 | 06:55 PM
AgRunner06's Avatar
How in the world did you get TB cleaner on the TPS?
In case you didn't know, the TPS is a PITA to adjust. It took me and another person to get mine right. Just leave it on there and watch were you spray.
Old Oct 18, 2004 | 05:51 AM
uxb101's Avatar
In case you didn't know, the TPS is a PITA to adjust. It to me and another person to get mine right. Just leave it on there and watch were you spray.
i got some of the tb cleaner in the tps im sure of it,also i went to replace the tps and both screws broke off inside the tb what a nitemare ,had to take off the tb and drill new holes after that i put hex screws in it incase i have to adjust it by the way my timing is at 10 how far advanced did you set yours?
i did the afm mod but i did not change my timing do you advance the timing after changing the afm?
Old Oct 18, 2004 | 06:15 AM
Well 10 degrees BTDC is ok I think, a lot of people use 12 and run premium and gain a little boost in performance.
LOL.....If i remember correctly mine is sitting at 15 or 17 or some ungodly ammount of advance and I've never touched it....I'll probably back it off to about 12 when I do the timing belt/water pump/idler. No pinging oddly enough...
Charecter1
Nov 6, 2023 10:08 AM
Jdgarrison
Oct 1, 2015 05:22 PM
Alex Bessinger
Aug 31, 2015 09:17 AM
ZONAYODA
Jul 13, 2015 07:17 PM
tobylab
Jul 12, 2015 12:53 PM
