Idler Arm Questions
Old Nov 16, 2004 | 09:27 PM
cvlighthouse's Avatar
should say MOOG on te box
Old Nov 16, 2004 | 09:34 PM
914runner's Avatar
Is Moog made specificly for Napa or is it just a brand that they carry? I have found that Napa likes to rebox pretty much everything in their boxes. Are there specific markings on the arm itself?
Thanks
Old Nov 17, 2004 | 12:52 AM
4RunnerKid's Avatar
Originally Posted by evilcow
Can you find out? let us know if it fits. Thanks.
I will for sure.
I just got it today actually. This thing is beefy. It should be plenty strong. I'm going to try and get it installed later this week sometime. I will let you guys know.
Old Nov 17, 2004 | 06:32 AM
Jeffires's Avatar
I'm thinking about ordering that Downey brace. Keep posting about your idle arms because I've had the same problems. The Napa (Moog) parts hold up alright, but I've gone through two or three of them. I want to get a Toyota arm and the brace to put over it; that way I can change the bushing if it goes out and not worry about bending the arm.
Old Nov 17, 2004 | 12:47 PM
  #25
Once you put the brace on there is no bending the arm. I have put a brace on over an aftermarket one and it worked fine. You'll save your self about $50 over the toyota one...
Old Nov 17, 2004 | 03:56 PM
  #26
914runner's Avatar
Well I just ordered the Moog arm since it has a lifetime warrenty. The part # is "268-3666".
Ill get a few pics when it comes in tomorrow.
Old Nov 18, 2004 | 05:15 AM
  #27
MenaceSQL's Avatar
When I tried to order a brace from Downey a few months ago, they asked if my idler arm was OEM or aftermarket. The Downey rep explained to me that their brace does not fit some aftermarket idler arms as the brace was designed around an OEM idler arm. Some aftermarket idler arms are thicker than the OEM ones explained the rep so the brace will not fit the thicker idler arms. I told them that it was an aftermarket and then told him that it is a MOOG after he asked if I knew what brand the aftermarket idler arm I had was. The Downey rep then told me that the MOOG is one of the ones that their brace will not fit. :cry:
Well, if you guys prove them wrong, I'll be getting me a brace too.
Old Nov 18, 2004 | 09:41 AM
  #28
4RunnerKid's Avatar
Hey guys, I remember I was charged like $200 for the new idler arm to be installed. Does that sound like an OEM arm price or an aftermarket price? Just curious... How much do they usually run? I didn't even bother asking because the whole lift situation was just one big mess anyways... :cry:
Old Nov 18, 2004 | 11:02 AM
  #29
evilcow's Avatar
Unless Toyota installed the idler arm its probably aftermarket. Now slap that gusset on and let us know if it fits.
Old Nov 18, 2004 | 10:16 PM
  #30
914runner's Avatar
I got the Moog arm installed, It is quite a bit beefier then the stock one and it only took me 45 mins to do it!
Old Nov 20, 2004 | 02:37 PM
  #31
4RunnerKid's Avatar
Gusset doesn't fit... So my choices are either get a new idler arm, or sell the gusset. What do you guys think? Is there an idler arm the gusset fits? It's far from fitting. The top part of the bracket that replaces the washer is way above the top part of the idler arm, if you know what I mean... This sucks...
Old Nov 20, 2004 | 03:01 PM
  #32
914runner's Avatar
Pics?
Old Nov 22, 2004 | 01:40 PM
  #33
leiniesred's Avatar
I never bent my arm with the brace. Did rebuild it once. I added a grease fitting to the front so I can grease the bushings to make sure the dirt gets out (no cap with the downey brace)
This is with 35's and a locker too.
andrewtexas123
Jul 6, 2016 01:49 AM
mbomberz1
Aug 8, 2015 06:57 AM
TJWilly
Jul 31, 2015 02:05 PM
kirkrunner
Jul 27, 2015 07:59 PM
ptb12
Jul 5, 2015 01:49 PM
