idler arm and ball joints
Old May 4, 2004 | 07:14 PM
95red4runner's Avatar
I went to get the old alignment done today and they called me back saying that I needed a new idler arm and ball joints and it would only cost $600 :pat: . Well I figure I can get the parts for a couple hundred bucks and try to do the work myself. So my real question is how easy/hard will this be and does anybody know of a writeup that may help. Thanks in advance.
------Steve
Old May 4, 2004 | 07:20 PM
86toyota's Avatar
How many miles do you have? I've never had balljoints go bad and I've owned my toys for many years(all over 200,00mi). I replaced my friends '89 idler at 213,000 miles. Did they show you all the play in them? Idler easy to replace, thou. Couldn't answer how easy BJ are since I never done them.
Old May 4, 2004 | 07:30 PM
It has just over 112,000 miles. They didn't show me but i played with it and it seemed that the right side had some play but the left felt pretty tight.
Old May 4, 2004 | 07:37 PM
Marc P's Avatar
I rebuilt my idler arm for $13.00 and an hour of my time. I dont know about the ball joints, but they dont look too hard.I am sure they include an alignment, but $600 seems steep.
Old May 4, 2004 | 07:50 PM
how did you rebuild your idler arm?
Old May 4, 2004 | 08:18 PM
Brendan's Avatar
open it up and replace the bushings. CLICK HERE
the other option is to go out and spend about $120 on an idler that comes with a lifetime warranty. if it breaks, bring it in and get a new one - no questions asked.
Old May 4, 2004 | 08:25 PM
Thanks sizzlechest
Now who knows about those darn ball joints?
Old May 5, 2004 | 09:57 AM
ed's Avatar
ed
Having replaced the balljoints and idler arm on both Toyotas I've owned, I've thought of the front end as being a weak area. Replacing the idler arm bushings is easy, you don't actually have to remove the idler arm stud from the steering link. However, the joint at that end can also wear out and then there's no choice except replace the whole unit with another overpriced chunk of steel.
Replacing ball joints is fairly straightforward technically but can be a pain depending on how much persuasion the taper stud needs to come loose. You'll need a C-puller, or pickle fork, or BFH. But really, other than that it's quite simple. You don't, contrary to the fact. manual, _have to_ remove the entire steering hub (though would give you more room). Searching should get you a list of instructions.
Personally, I'd do both - you might as well. I did this a few months back, this time I used aftermarket parts; came in half the price of toyota ones.
ed
kawazx636
Oct 6, 2021 03:03 PM
4x4YOTA
Aug 23, 2016 09:08 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
crash813
Sep 27, 2015 07:15 AM
Odin
Sep 26, 2015 06:56 PM
