Idle stumble whil in gear
Old Aug 5, 2005 | 11:17 AM
JEDI87's Avatar
I have an annoying problem.While idleing the truck has a stumble,tach doesn't move and it only does it while in gear.When it is in park it idles smooth.It idles....stumbles,idles...stumbles,etc.Any ideas?I have replaced the spark plug wires and plugs.It has a new distributor,cap,and rotor.
Old Aug 5, 2005 | 11:47 AM
JL8Jeff's Avatar
Sounds like the idle air adjustment screw is out too far. Which truck is this happening on? When I had my 90 V6 pickup the idle air adjustment screw on the throttle body had backed it's way out some and the idle got higher and would stumble when it was in gear and I had my foot on the brakes. I just turned it back in a turn or 2 and the idle went down and no more stumble. Check that first.
Old Aug 5, 2005 | 11:56 AM
JEDI87's Avatar
It's on the 91.It does idle a bit high,about 1000-1100 rpm
Old Aug 5, 2005 | 12:32 PM
89macrunner's Avatar
Seafoam!!!!
Old Aug 5, 2005 | 12:37 PM
jimbo74's Avatar
automatic or stick? if the clutch is out of adjusment it might be partially rubbing or not disengaging causing a quick hit and htus the stumble.... if i idont make sure my clutch is pushed in 100% it idles rougher than neutral
Old Aug 5, 2005 | 02:53 PM
JEDI87's Avatar
Auto.I have done seafoam 2 times and it mad a huge difference in other ways.
Old Aug 6, 2005 | 07:33 AM
JL8Jeff's Avatar
Try what I suggested. Adjust the idle air screw on the throttle body and your idle should drop down and it might make the stumble go away.
smthwsn357
May 1, 2024 07:28 AM
montanatruck
Feb 26, 2017 07:07 AM
pyramid
Jul 30, 2015 10:05 AM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
Jnkml
Jul 6, 2015 01:20 PM
