Idle spped issue
Idle spped issue
My 81 22R will idle high when it is cold, but it will idle high for far too long. I removed the air cleaner while it was idling so high and tried to open the choke places and or unstick anything that seemed stuck but it continued to idle high for a maddening length of time and I found no moving part that changed the idle....Eventually a swift pump of the accellerator slowed the idle back down but it took way too long and the engine was way warmer than it needed to be. I read in a manual at the library that there is no possible idle adjustment in the 81 model. Is there a simple choke adjustment that will fix this problem?
Sounds like the choke needs to be replaced.
An electronic choke is inexpensive and will
resolve the issue of high idle too long.
EDIT:
There is a kick down circuit that is linked to the throttle cable cam.
The cam has a screw that can be moved back and forth to adjust idle.
Follow the throttle cable into the carb and you will see the cam, the kick down circuit, and idle adjustment screw.
EDIT:
Check the voltage meter on the idle control sensor, and don't forget to check the main computer for any error codes. I had the same problem and I found that the sensor was bad; probably cost me 150 bones but will fix the idleing.
M
M
If the choke is a mechanical type then it will be necessary to by the rebuild kit. However, there is always the junk yard
I might same the same for electronic chokes. Try some carberator cleaner.
.I might same the same for electronic chokes. Try some carberator cleaner.
montanatruck
Feb 26, 2017 07:07 AM
