I still am having trouble understanding the intake silencer mod.
Old Nov 15, 2002 | 12:01 PM
Glassjaw19's Avatar
no one around here carries a 1/2 x 3/16 Tee for the EVAP Hose and my 1/4 TEE doesn't even fit over the Plenum. The tubes go on it nicely, but I can't get it plugged into the plenum.
Old Nov 15, 2002 | 12:11 PM
loosehead's Avatar
I guess I don't understand where it doesn't fit. I thought you meant the T's were too small and were loose in the evap line. Can you explain a little more?
Old Nov 15, 2002 | 12:18 PM
Glassjaw19's Avatar
Sure, I haven't tried the EVAP line yet. I was told by Dr. Z to get a 1/2 x 3/16 TEE for the EVAP line. So apparently I should really get a 3/8's TEE for the EVAP line. OKay, I'm on my way to Pep boys. With The plenum. I can't get my 1/4 TEE to fit on to the Plenum. Thats whats wrong with it. I can get the FPR and PSP Tube connected to it just fine but to actually put the 1/4 tee on to the actual Plenum, well it just doesnt' fit. The only way I see it fitting, is if I were to cut some PSP tube off and slide it over teh Plenum, then I could kinda attach the 1/4 tee onto the tube that hangs over the plenum. But isn't that kind of a "mickey mouse" way of connecting the 1/4 tee to the plenum?
Old Nov 15, 2002 | 12:27 PM
loosehead's Avatar
O.K., I think I understand. I don't think what you described as "mickey mouse" necessarily is. It pretty common place when splicing in a T, you just cut the line where you want it and add the T. So by leaving a little piece on the plenum to attach the T to should be just fine. (If I amunderstanding you correctly)
Old Nov 15, 2002 | 12:33 PM
  #25
Glassjaw19's Avatar
haha, by mickey mouse i meant BAD. Isn't it bad to just have a tube coming off the plenum just so you can plug in a TEE, i mean shouldn't everything be a direct conection?
Old Nov 15, 2002 | 12:46 PM
  #26
loosehead's Avatar
My answer is still no, direct fit is not necessary. Go back to the write-up and look at the 7th pic from the top, on page 1, this is how Dr. Z has done it - a short piece of tube connected to the T. It looks "factory" to me...
Old Nov 15, 2002 | 12:58 PM
  #27
Glassjaw19's Avatar
well awesome, I got all the TEEs and I"m giong to do the Dirty Tape method. This will be fun. Thanks for the help and not killing me
Old Nov 15, 2002 | 01:03 PM
  #28
loosehead's Avatar
Kewl! Let us know how you like when you're done, or if you have any more questions in the meantime.
Old Nov 15, 2002 | 01:33 PM
  #29
Dr. Zhivago's Avatar
Away
Right on Glass! Glad to see you finally got it! Enjoy!
Dr. Z
Anthony Lee Mathis
Sep 15, 2015 07:22 AM
skouba
Sep 14, 2015 06:58 AM
viesail
Sep 5, 2015 04:23 AM
128keaton
Sep 3, 2015 05:09 PM
DiggnDeep
Sep 3, 2015 02:45 PM
