I need front rotors.
Old Nov 13, 2003 | 06:18 PM
KING's Avatar
TOYOTA has them for 102 dollars a piece.
CHECKERS has them for 40 dollars, though I think they're sold in pairs.
Is it worth it to pay for the genuine parts? Are they that much better?
Old Nov 13, 2003 | 07:24 PM
AgRunner06's Avatar
Post
I don't think it's worth an extra $120. Mine were $37 a piece at Napa so I think the $40 is per rotor. I just used the ones from Napa along with Toyota grease seals. I haven't had any problems but they've only been on for about 2K miles.
Old Nov 13, 2003 | 07:56 PM
KING's Avatar
How much were the grease seals?
Old Nov 13, 2003 | 08:09 PM
paxam's Avatar
I got brembo rotors and napa pads .. my toy stops very good...
Old Nov 13, 2003 | 08:17 PM
AgRunner06's Avatar
Post
$30
Old Nov 13, 2003 | 08:32 PM
mkool's Avatar
Check this out
Brembo rotor
I might order this .. I always have been hate soft brake power. I'm gonna do something about this soon.
Old Nov 14, 2003 | 07:00 AM
KING's Avatar
Originally posted by mkool
Check this out
Brembo rotor
Nice....
So it's $100 per pair, meaning both sides??
Are the combos worth the extra $75?
Also, do I need pads if I'm changing the rotors or only if they're worn out?
(I've never done any brake shops, keep that in mind).........
Old Nov 14, 2003 | 07:06 AM
CTB's Avatar
CTB
Nice....
You might as well replace them while you are in there. It isn't a very big expense, and will save you some hassle in the future.
Old Nov 14, 2003 | 07:29 AM
KING's Avatar
True indeed, thanks for the advice.
Old Nov 17, 2003 | 07:18 PM
KING's Avatar
OK, so If Im doing a complete break job, what do I need besides the rotors (2), pads (2) and grease seals (2?)?
Old Nov 17, 2003 | 07:23 PM
CTB's Avatar
CTB
A bearing packer to pack the front bearings with grease, 4 pads (2 per side), grease seals like you said, rotors like you said....I think that is it.
Old Nov 17, 2003 | 07:32 PM
KING's Avatar
There's 2 pads per side? I must be dumber than what I had actually thought.
So I just ask the TOYOTA guy for a "bearing packer"?
Old Nov 17, 2003 | 08:49 PM
AgRunner06's Avatar
Post
You can pack the bearings by hand. It just takes a minute. If I were you, I would have someone that has done a full brake job with you when you tackle this project. My buddy helped me do mine and it really helps to be able to bounce ideas and questions off him when you aren't sure about something.
I'm not sure about the bearing packer. I've never used one before. I don't think it will be a dealer item though.
About the pads, they are sold in pairs. Just tell him you need front pads. When I did my brake job I didn't change my pads because they were only about 10K old and still had about 1/4" left until the wear tab.
Good Luck
Old Nov 17, 2003 | 09:10 PM
Churnd's Avatar
Front End Maintenence
If you have manual hubs, you might want to get parts to rebuild those too since you're going to have to take them off anyway. I think you might need a pair of new star washers, but it's been so long since I've done mine I can't remember if I replaced them or not. Make sure you have a 54mm or 2 1/8" socket. That's all I can think of for now. Good luck getting that rotor off... mine was a bitch and a half.
Old Nov 17, 2003 | 09:12 PM
AgRunner06's Avatar
Post
PB Blaster is your friend. Mine were a piece of cake. It may have had something to do with them being off only 10K ago.
Old Nov 18, 2003 | 06:41 AM
KING's Avatar
Thanks for all the advice.
Now, I'm just looking for the better of four prices, locally.
By the way, it's not manual hubs.
Old Nov 18, 2003 | 06:55 AM
keisur's Avatar
I used a 5 pound rubber hammer to beat on the bottom of the disc surface and the thing popped and kinked over and loosened right up, yes PB Blaster helped a little.
88sasturbotoy
Jan 30, 2026 01:57 PM
ty1er
Aug 1, 2015 11:53 PM
Sr5crawler
Jul 31, 2015 12:32 PM
coffey50
Jul 28, 2015 10:55 AM
Steven.m.paulk
Jul 24, 2015 01:44 PM
