I have some questions,...
Old Nov 3, 2003 | 07:50 AM
rixham's Avatar
cruizin01 - thanks man. I was worried that I had the soft part numbers. But since they are firm. I am going to get them. Again thanks.
Old Nov 3, 2003 | 09:50 PM
overKILL's Avatar
So,... so you say if I lift my truck more than 3" I will have to worry about my CV's,... so if I lifted my truck up about 3" and then installed the 4Crawler 1" differencial drop kit,... I wouldnt have to worry at all about my CV's?
Old Nov 3, 2003 | 09:53 PM
nightsurfride's Avatar
You got it!
Old Nov 3, 2003 | 09:56 PM
You may have some CV grease start coming out the inner boots, but taking the OE clamps off and installing stronger hose clamps in place does the trick
Old Nov 4, 2003 | 01:22 AM
  #25
overKILL's Avatar
Ok,... cool. So,... I'll get a 3" lift, drop the diff 1", lift the body up 2", and then install 32 0r 33" inch tires,... I might go with 32,... depends. I have been looking through my Haymes manual getting an idea where everything is and what everything is,... I rebuilt the top end of my porsche 944S so I think I can handle this. Does anyone know ehere I can get the factory manuals online How about blown up images of the truck? Porsche has this program called PET that is nothing but blown up images of the cars. They use it to get part numbers and such,... anything like that for toyota?
Old Nov 4, 2003 | 01:43 AM
  #26
overKILL's Avatar
Ok,... so the Total Chaos system,... $3,200!!! So,... now thats out of the question,... I think I might do somthing like cruizin01 setup. Yup.
Old Nov 4, 2003 | 04:51 AM
  #27
cruizin01's Avatar
Hey overkill..If your only gonna run a 32 inch tire im assuming itll be an 11.50 I would probably go with an 881 coil and if your worried about the rear-end riding a little high you might consider adding a small spacer with that. I am considering picking up a set of 881 and a 1 inch spacer to c if I can get a little better ride from mine. I dunno if that will work or not. worth a shot i guess...If I had 650 bucks Id just get me a pair of SAWs and not have to worry
Old Nov 4, 2003 | 05:23 AM
  #28
overKILL's Avatar
What are SAWs?
Old Nov 4, 2003 | 05:26 AM
  #29
CTB's Avatar
CTB
Originally posted by overKILL
What are SAWs?
He is referring to Sway-A-Way's. They are a combination spring and shock (coilover) for the front of 3rd Gen 4Runner's and Tacoma's with the front coilover suspension.
  #30
waskillywabbit's Avatar
What are SAWs?
Thing you use to cut wood!
Look here, they are coilovers.
http://fastq.com/~sschaefer/saw.html
Old Nov 4, 2003 | 05:27 AM
  #31
CTB's Avatar
CTB
HaHa....beat you Brian!
Old Nov 4, 2003 | 05:28 AM
  #32
Au contraire
But I had a link with pics!!!
Old Nov 4, 2003 | 07:57 AM
  #33
cruizin01's Avatar
overKILL check your PM
lectric80
Aug 11, 2015 12:02 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
4Runnin2000
Jul 29, 2015 06:09 PM
