!!!! i have a slight emergency with fuzes and battery!!
Old Nov 28, 2008 | 09:22 PM
czar's Avatar
Exclamation !!!! i have a slight emergency with fuses and battery!!
Ok so i replaced my battery with a optima and accidently reversed the polairty and then changed it back but i think i blew a few fuses, i was wondering if i use the battery and replace the fuses with others of the same size but higher voltage would it hurt my car?
Old Nov 28, 2008 | 09:25 PM
Elton's Avatar
dont use higher than what it says just replace the ones that you blew and you should be fine
Old Nov 28, 2008 | 09:26 PM
DeathCougar's Avatar
DO NOT use higher amperage (not Voltage) fuses. They are set to pop before the capacity of the wires are reached. If you use higher amperage fuses, you risk setting your truck on fire in the event something grounds out, OR if you messed anything up by crossing the cables.
RECAP: Overloaded wires=FIRE
Old Nov 28, 2008 | 09:30 PM
czar's Avatar
well its hooked up straight right now but i just have to touch the old fuze thats broken off in my fuze box to my new one and it starts what amerage battery is normal for a 4 runner because i have a very power hungry stereo that uses alot of my batter.
Old Nov 28, 2008 | 09:36 PM
czar's Avatar
Old Nov 28, 2008 | 09:37 PM
czar's Avatar
Old Nov 28, 2008 | 09:41 PM
Elton's Avatar
holy triple post bat man
Old Nov 28, 2008 | 10:37 PM
Ohio4R's Avatar
Dude can you please learn how to spell, i went through your posts and could barely read them.
NOTE TO SELF THIS IS HOW YOU SPELL FUSE
Old Nov 28, 2008 | 10:55 PM
Elton's Avatar
Old Nov 29, 2008 | 07:01 AM
czar's Avatar
i had a question i was not asking to be judged i do not spell very its not one of my strengths, isnt this forum supposed to be for help and advice, and not to say rude S#$@ to people
Old Nov 29, 2008 | 07:27 AM
DailyDrive's Avatar
Being illiterate does not quite disqualify you from working on cars, but hooking up a battery backwards certainly does! Best advice is for your own and everyone else's safety is to outsource your car repair
Old Nov 29, 2008 | 07:41 AM
czar's Avatar
thanks for the help guys im out of a car and so far iv got nothing but critisizm from people, this is really good forum
Old Nov 29, 2008 | 07:54 AM
weaselman's Avatar
just replace the fuses that blew with the same size fuse. the only reason they blew is becuz you freakin hooked it up wrong. its not that hard to figure out. i mean come onnnnnnn. seriously?
do not use any higher than oem spec fuses otherwise your car will catch fire
Old Nov 29, 2008 | 08:00 AM
Nothing but criticism? I believe I explained exactly what you need to do without critisizing you one bit. Like i said, replace the fuses with the correct amperage fuses. Higher amp fuses can cause a fire.
Old Nov 29, 2008 | 08:02 AM
czar's Avatar
well i belive that the fuse trey comes out so that the fuses can be losend by some 8 or 10mm bolts as i have been reading other places but i cannot figure out how to get the fuse trey out to do so.
Old Nov 29, 2008 | 08:04 AM
It slides out the bottom of the fuse block, and is clipped in. Depending on your year, the clip may be on the top of the fuse block, or inside of it.
Old Nov 29, 2008 | 08:05 AM
czar's Avatar
it is a 2000, so do i need to un bolt the whole fuse box inorder to remove it.
Old Nov 30, 2008 | 07:39 AM
You have to unbolt the bust block no matter what year it is. You have to have the clearance to slide it out the bottom.
cpljenkins01
Sep 7, 2015 09:50 AM
Gone Fission
Sep 4, 2015 12:18 PM
Scatterbrain
Sep 3, 2015 06:46 PM
RobotMoose
Sep 2, 2015 05:53 AM
bvleonov
Aug 22, 2015 11:39 PM
