I hate my 2WD!
Old Feb 20, 2003 | 10:31 AM
rimpainter.com's Avatar
Re: Heavy is good for gription! Add a cheap rear locker like a lock-right, it's simple to
Originally posted by JLSubThumper
about the lock right my friend has a 89 toyota supra and he is making it into a drag car so he needs a locking rear end with 410 gears. he has limited slip right now but he wants locking obviously so will that lockright bolt on to his rear end and make it a locking rear or is that a hole new dif? what would be best?
If you are asking about a drag only car, then locking the rear diff would be ideal - but a good limited slip should be sufficient in causing the rear to "posi up" when launching. Besides, with a locking rear diff, any turning will cause undue stress on the components, and could cause breakage, even when turning in the pit area.
I would say stick with the LSD.
Old Feb 20, 2003 | 10:40 AM
JLSubThumper's Avatar
are you talking about wheel hop there? and the car is going to be used as his daily driver is the lock right a hole dif or just an atachement that makes it a lokcing electronicaly condroled dif?
Old Feb 20, 2003 | 10:45 AM
how do i get the quote in the lines like you did?
Old Feb 20, 2003 | 10:48 AM
"Posi up" is slang for "Positive Traction" - referring to both tires peeling out at the same time. That's my understanding anyway.
So, if your friend is trying to avoid being a "one-wheeler-peeler" and remain a daily driver at the same time, I would go with an LSD.
It sounds like you are asking if he could hook up a rear diff locking system similar to the TRD, or ARB set-ups. Well, all I know is that the TRD e-locker is not supposed to be operated above 5MPH, so that could pose a problem in a 1/4 mile run.
Of course, I dont know EXACTLY why Toyota has that restriction on the e-locker...
Old Feb 20, 2003 | 10:50 AM
  #25
By clicking the "quote" button in the message you are responding to. (Bottom right)
Old Feb 20, 2003 | 11:25 AM
  #26
CTB's Avatar
CTB
Originally posted by <96 Runner>
"Of course, I dont know EXACTLY why Toyota has that restriction on the e-locker...
Well, I personally can't think of a reason you would need a locker if you were going more than 5 mph. It would be hard to crawl over obstacles at more than 5 mph.
However, I think it must just be engaged below 5mph, but once engaged, you can travel faster than that.
Old Feb 20, 2003 | 11:36 AM
  #27
You might be right. Maybe they just dont want you to engage it above 5MPH, because it could damage it. From there, I guess you could go as fast as 4LO would let you.
Of course, I knew a trick to get the locker to stay on, even in 4HI.
ladybugRC
458
Aug 21, 2020 10:41 AM
Dale Johnston
11
Oct 31, 2015 10:22 PM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
Flightguy
Oct 2, 2015 05:34 PM
Cycles
Sep 29, 2015 06:37 AM
