Hyperground kits
Old Jun 2, 2003 | 11:55 PM
Praufet's Avatar
Hyperground kits
Has anyone tried these? Do they work or is it just another gimmick? I can't really see how they would boost performance. For those who haven't seen them....
Hyper Ground
For Sale
I have seen them for less, this is just an example
Also here's something cool on ebay
Digital A/C panel
Old Jun 3, 2003 | 01:14 AM
4x4runner's Avatar
Definitely a gimmick. Looks like a pack of large guage stereo power wire. If you want to do it, just pick up some zero guage power wire and some terminals for a lot less.
Old Jun 3, 2003 | 02:38 AM
david in germany's Avatar
import tuner
import tuner mag has been occasionaly been using the kits on some of there dyno runs and have made gains of 2-5 hp on some of the installs. the kits create a hp by reducing bad grounds for the computer.
yes you could just use multiple grounds to get the same setup.
David
Old Jun 3, 2003 | 03:20 AM
DuB's Avatar
DuB
Ever since the start of the import scene, I've been weary of anything that started with Hyper- or Hiper-
Old Jun 3, 2003 | 06:10 AM
rimpainter.com's Avatar
SCC just tested these on a new Z, which runs the coil on cyl VQ engine. They saw gains of over 5HP at the wheels.
Doesn't sound like a gimmick to me. The key is finding the best ground, which is trial and error.
Old Jun 3, 2003 | 09:01 AM
turboale's Avatar
A buddy of mine put one on his z... he said he could tell a difference. Not sure about our engines though. Don't know how much good it would do. I do agree with what was said though. Just go get some good stereo wire and do it that way.
Old Jun 3, 2003 | 10:03 AM
Bumpin' Yota's Avatar
I have a VERY VERY hard time believeing even 2hp at the rear wheels from that kit. The computer is grounded via it's own harness using what, 16ga wire? Those are merely stinger HPM 4ga wires with clamp on terminals intended for the electrical system not the ECU. Physics here.... the only way to increase power is to make the main shaft spool up faster. This can be done by reducing drag. The only drag on the main shaft electrically is the alternator - so disconnecting the alt would provide a MUCH better gain that this mod would. (however your battery would die relatively quickly...
The only thing it would do is allow better transfer of power from your alt to the battery etc. It WILL make a differnce on any high powered sound systems or will help with a hi output alt, but HP gains? I just dont see that at all. Something like that must be tested on the dyno as people who "feel" a difference are probably experiencing the placebo effect. Just like how the power toilet has proven to reduce power in the 3.4L but people "feel" a power increase - placebo.
Old Jun 3, 2003 | 11:00 AM
Dude go to Barnes and Noble and grab the latest issue of SCC. If that's not enough documentation, I dont know what is. (They may have used a different kit on the Z) but again, the VQ is not that far off in engine design from the 3.4.
And the power toilet works! Check my sig.
viesail
Sep 21, 2015 06:00 AM
Adam Edgar
Sep 20, 2015 03:24 AM
sonorn67
Sep 19, 2015 05:39 PM
JookUpVandetti
Sep 17, 2015 09:25 PM
Patrick1976
Sep 15, 2015 11:33 PM
