How to remove humidity inside?
Old Jan 23, 2005 | 11:31 AM
Fahrenheit 451's Avatar
Go to Payless Shoestore, try on 1,428 different pairs of shoes. Buy one pair. Put all the little packets of silica gel dessicant from all the shoes you tried on in with the pair you buy. When the clerk gives you the stink eye tell them you have awful sweaty feet. Install in your truck. Voila!
Old Jan 23, 2005 | 11:43 AM
4Crawler's Avatar
Originally Posted by 4RUNR
Well, the source is obvious. Opening the door to get the snow brush, then opening another door to get in coats the inside with snow. Even though I have rain-guards, opening windows even a smidgeon when it’s windy and snowing would result in a snow drift on the seats.
I tried Rain-X on the inside, since I had a bottle anyway, and it *seems* like it's not forming ice in the same place. But will have to give it more time to be sure.
Try the Fog-X stuff for the inside instead of the Rain-X. Also, really clean the inside of the glass. I like to use a straight alcohol to strip the glass of oily residue then glass cleaner to clean the residue from the alcohol then buff it out very well.
When my A/C worked in my '85. I had to manually engage it with defrost to have it help dehumidify the air. Now that I no longer have it, I have to use heat only. The trick is selecting whether to use fresh or recirc. If the outside air is cold and dry, I use fresh, but if it is foggy, raining or snowing outside, I'll try recirc.
Old Jan 24, 2005 | 12:11 PM
Flamedx4's Avatar
1. Open window.
2. Stick head out window.
Old Jan 24, 2005 | 12:15 PM
Flamedx4's Avatar
You have that backwards. If it's foggy rainy or snowy you NEED fresh intake to circulate the moisture from your breath and body out. Otherwise you become one of those bozos you see driving around with moisture dripping down the insides of their windows.
It's really easy to remember. There is never a time for recirc except when you want the fastest possible cooldown in AC on a hot day. Cars that don't let you choose fresh/recirc work that way - only closed the outside air door on Max AC, all other positions are bringing in fresh air.
Old Jan 24, 2005 | 01:15 PM
  #25
89macrunner's Avatar
you can get GIANT silica things from a lot of old car parts places like roadster factory etc...we got a 25lb one for like $30 or something
Jcrawl94
10
Oct 24, 2015 04:34 PM
JAmdor3
Aug 11, 2015 10:53 AM
mtc1105
Aug 4, 2015 08:06 PM
58rennur4
Aug 4, 2015 08:49 AM
crashburnoveride
Jul 10, 2015 06:39 AM
