How many miles on your 3.4L timing belt?
#61
I can do the timing belt replacement in about an hour on my 3vze. Let me also say I have done it 3 times. The first time it took 3 hours cuz I wrote down everything and replaced the water pump as well. The third time it took about an hour since I already knew what to do.
#63
Originally Posted by midiwall
do you have a credible source that extends beyond certified master mechanics?
"3.4 in non interference."
Source: Some page number is a bulletin or manual published by Toyota.
...is better than...
"3.4 is non interference."
Source: The God of all mechanics in this hemisphere I called at the local Toyota dealer yesterday.
#64
Originally Posted by MTL_4runner
You saw from what I posted that they had conflicting charts so I would say the Gates chart is crap.
It was pretty clear that the Gates reference was worthless once people started putting the question to Toyota.
My issue at the moment is 4RUNR seemingly not liking the word of Toyota certified mechanics either.
#66
Let's be realistic, nobody knows everything there is to know about Toyota. And that includes even those that pass a certification.
Print always takes precedence over word, even if Hiroshi himself says that the 3.4 is interference.
#67
Three points...
- I figure you understand that, in cases like this, the printed word has to come from a human right? i.e., a human had the knowledge before it was comitted to paper.
- And you're saying that you don't believe in the transference of the written word? i.e., a human cannot be trusted to be able to absorb the written word from a credible source? So we can just pass out books and do away with teachers.
- And what do you do when Bill Gates says that Windows is "the end-all OS for the world"; Steve Jobs says "Apple OSX is the end-all OS for the World" and then Microsoft publishes a document that says "Windows is the end-all OS for the world"?
Do you then think that Windows is the end-all OS for the world?
#68
#69
Ok, let's settle this once and for all.... for the 1999 Toyota 3.4L engine, they are non-interference. this is from actual measurments of the valves at full open, Both the intake and exhaust extend 3.8mm beyond the mating surface of the head. The piston is cupped and is 4.6mm deep. that is a .8mm gap without adding the thickness of the head gasket.
Where did I aquire this information, easy, I measured it myself.......
#70
Yes, I do trust someone reading sources then relaying them here; the caveat is the source should indeed be credible on the subject matter, and verifiable if need be.
So we need to dig up the training materials to be sure that a) they were taught "correctly" (defined as being taught what the training materials said, though I'll assume you agree to the first point above), b) they relayed their memory of the training materials correctly.
As well, I guess we also need to find the FSM which may/may not be the same as the training materials, and if not, then it may not have even come from the same original knowledge source of the training materials - which I'll assume that we agree was human.
This is fun.. how far do you want to take this before you agree that BeOS is the best OS even written?
#71
Bruce, thank you for finally ending this debate.
Jared....are you sure you don't want to retract that statement about your friend's dad?
#72
Oh, I guess I should add what are my credentials? I'm a Certified Master Technician with over 25 years experience. I can't even count the number of engines that I've built/re-built, way too many to remember. The source for my measurements came directly from an engine I have in my backyard that I blew up last year.
#73
J/K!
#75
The court has already established as a fact, that the timing belt broke, and that total engine failure will incur with no fault from the plaintiff if the engine was interference by design.
Now, the defendant brings in an expert witness, a certified master technician that says the engine is non interference and the damages caused were the result of negligent actions on behalf of the plaintiff. Remember, imaginary.
The plaintiff brings up an official Toyota corporate document stating that the engine is indeed interference.
Who's evidence will have more weight?
#76
Physical proof is always better than written documents, so as an "expert" witness and with the engine in the court room, a simple demonstration that the valves can't hit the piston, would be evidence enough, to prove beyond a shadow of a doubt that it's a non-interference engine.
Back to reality, I'll personally wait til my timming belt breaks to fix it, then we'll see who's right.
BTW I did take a few photo's if you don't believe me....
#77
#78
Yeah, hold today's newspaper next to it too!
But, assuming that there is no physical evidence, or the problem was more complex, even doesn't have to be about engines, and it's the expert's word against the manufacturer, the manufacturer will have more credence.
To make an analogy: no matter what experts exist out there, nobody knows better than me how many beers are in my fridge. Same with the engine, no none knows better than the manufacturer.
#80
Here's the shots
i think this finally answers everyones questions. pictures speaks alot more than words. i asked my friend who is an toyota mechanic and he said non-interference motor.
