How many miles on factory clutch?
Old Feb 23, 2004 | 12:27 PM
rimpainter.com's Avatar
You mean force it out of gear without using the clutch? Not me, I always use the clutch.
Old Mar 6, 2004 | 08:28 AM
mike_d's Avatar
Originally Posted by mike_d
i've got 228K on my 1st gen with 50/50 highway/city driving. it's getting close to replace time though. it only take a 1/2 in of pedal movement to go from off to on. but it's not slipping yet.
update: the final tally is 229191.7 miles on the origianl factory clutch. it didn't start slipping, but i did take it in to my mechanic because i'm going to be heading out to canyon lands and moab in a couple of weeks and didn't want any catatrosphes when i'm a couple hundred miles from home. anyway, my mechanic called me at work to let me know what needed to be done and everything, and his exact quote was: "um, yeah, i don't even know how you drove it here" so i guess the clutch was in quite bad shape.
Old Mar 6, 2004 | 08:59 AM
Nic's Avatar
Nic
My 84 Camry has 256,000 miles with the original clutch and works just fine-shifts better than my truck too.
My truck has 120K miles and I'm sure it has the original clutch.
Old Mar 6, 2004 | 10:06 AM
Juggalo's Avatar
Originally Posted by miked
I got a question for you guys. When coming to a stop, do you disengage the clutch and then shift into neutral or do you just shift into neutral. I've always done the disengage then shift into neutral but I know some people who just shift into neutral without disengaging.
It's very easy to do that, just tap the gas pedal and when letting of (the gas) the shifter will be very easy to put into neutral. I've tried that a couple of times, hell I've even shifter from 1-2, 2-3, 3-4, 4-5th without the clutch, but it's just not that good to do in my opinion.
BTW my truck has 194,000 miles on the original motor, and what sucks is I have no idea if the clutch has been replaced or not. It feels good, but even with my old 31's it just wouldn't chirp 2nd gear, so I'm guessing that it's still stock.
On a side note, how is the TRD clutch/flywheel combo? Anybody have it?
Old Mar 6, 2004 | 05:07 PM
  #25
toy283's Avatar
232,240 and counting.
bigjstang
Jun 2, 2025 03:56 PM
smthwsn357
May 1, 2024 07:28 AM
mskalmus
May 28, 2017 07:51 AM
Poncho0206
Jul 10, 2015 06:21 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
