MPG calculation: Help needed please
Old Mar 5, 2004 | 04:43 PM
rimpainter.com's Avatar
My rig new had 265/70/16's. The tires were upgraded by the previous owner to 265/75/16's. I have been dividing my accumulated mileage per tank by the number of gallons used. I believe my odometer is slightly off due to the slight increase in tire size. My question is: How much is it off?
I will add the % increase to my excel spreadsheets to "correct" the equation.
I suck at math, and I really suck at story problems. Please
Old Mar 5, 2004 | 05:03 PM
Glenn's Avatar
Why not check it with GPS?
Old Mar 5, 2004 | 05:07 PM
Because I dont have GPS.
MTL_4runner's Avatar
Ok, I will take a stab at it.
original tires:
radius wheel = 265mm*%70= 185.5 mm or 7.3 in of sidewall + 8 inches or rim = 15.3 in
cirumference is 2*pie*radius = 96.08 inches
New tires:
radius wheel = 265mm*%75= 198.75 mm or 7.8 in of sidewall + 8 inches or rim = 15.8 in
cirumference is 2*pie*radius = 99.22 inches
so I get a difference of 99.22/96.08 = 1.032 or 3.2% larger
Old Mar 5, 2004 | 05:08 PM
Really? That much? Wow...anybody else?
Old Mar 5, 2004 | 05:09 PM
Sorry, needed to recheck my math!
Made a calculation mistake.
Should be about 3.2%
Old Mar 5, 2004 | 05:11 PM
Thanks Jamie. So I should add 3% to my excel spreadsheet right?
bamachem's Avatar
yup... about 3.5% difference... multiply your mileage calculation by 1.035
Old Mar 5, 2004 | 05:12 PM
Exactly!
Hey, engineering does come in hand after all.
Old Mar 5, 2004 | 05:16 PM
Awesome, thanks a ton guys. I incorporated it into my spreadsheet.
Old Mar 5, 2004 | 05:18 PM
Just a by the way, I used 25.4 for converting mm to inches and 3.14 as pie.
I don't think you need to be any more precise than that tho.
Old Mar 5, 2004 | 06:01 PM
bamachem's Avatar
The toyota odometer and speedometer aren't synchronized exactly either - or so I've read... Supposedly, with 265/70's the speedo is off by about 3-4% (you're going slower than it says) and the odo is dead on. With 265/75's, the speedo is now DEAD on and the odo is reporting 3-4% less distance than you actually traveled...
Old Mar 6, 2004 | 08:19 AM
hypnotoad's Avatar
How much do you subtract, and at what rate, for the wear of the tires themselves? They aren't the same diam when they're worn as when new. In other words, it ain't accurate to begin with so all this math is like tuning up the band while the ship is sinking - fruitless.
Old Mar 6, 2004 | 08:24 AM
You are right, they do change diameter but it is so small relative to the size of the tire that it becomes negligible.
bamachem, has a good point. You need to know what tires came stock on the vehicle to calculate the total difference between your current tires and the stock tires (assuming the odometer and speedometer were dead on when new). Otherwise the best you can do is calculate the relative difference between the MPG of the old and new tires.
Old Mar 6, 2004 | 08:29 AM
kford's Avatar
WTF
Post size must be 15 characters...
Old Mar 6, 2004 | 08:32 AM
hypnotoad's Avatar
I figure the overall diam reduces by at least an inch (1/2 inch or more all the way around) - sounds ligible to me. (is that the opposite of negligible?)
Old Mar 6, 2004 | 08:38 AM
good one!
I suppose if you go from brand new monster mudders to totally bald nobbies you would see a decent difference. It would take quite a while to show tho. You might be looking at a max difference of like 1-2% at the worst case.
Old Mar 6, 2004 | 09:55 AM
ALBPM's Avatar
This is a handy tool..
http://www.miata.net/garage/tirecalc.html
Old Mar 6, 2004 | 11:17 AM
RidgeRunner's Avatar
I use 3% increase average, got that tip from Dr. Z.
Mick
Old Mar 6, 2004 | 04:26 PM
mike_d's Avatar
doesn't matter, both divide out since all you care about it a ratio between old and new.
