How the heck do you remove the trans pan?
Old Apr 14, 2007 | 03:39 PM
bmwpower's Avatar
It's stuck on there pretty good with some sort of red factory sealant. The shop manual says to use some special tool with a blade...don't have it.
Help! Sitting under my truck trying to figure out what to do next.
Thanks!
Old Apr 14, 2007 | 03:47 PM
Greedy's Avatar
Just work a screwdriver or paint scraper around the edge and gradually pull the pan away from the tranny. Toyota uses the red sealant instead of a gasket on our trans pans (and oil pans) so before you reinstall it you will need to clean off both surfaces anyways.
Old Apr 14, 2007 | 03:52 PM
bmwpower's Avatar
Oh boy. I'd to hate use a screwdriver the flange like that, but I will give it a try.
OK to use the Right Stuff to reseal the pan?
Old Apr 14, 2007 | 05:31 PM
bmwpower's Avatar
Ok... got it off with the help of a deadblow, razor and a screwdriver...
Now how do I maneuver it out of the way??!?! I can't seem to figure out how to drop the pan out..
THanks!
Old Apr 14, 2007 | 05:43 PM
bmwpower's Avatar
Do I have to drop the front swaybar??
Old Apr 14, 2007 | 05:50 PM
4banginRunner's Avatar
i had to drop the swaybar to get the tranny pan off my 90 4Runner if that helps
Old Apr 14, 2007 | 05:55 PM
CyMoN's Avatar
guess I am a little late a 4 to 6 inch putty knife works well for breaking the seal as well
Old Apr 14, 2007 | 06:00 PM
bmwpower's Avatar
Ok....
I think I got it....
You need to drop the truck to the ground so the swaybar is preloaded. With the swaybar tweaked a little bit, you have enough room to lower the pan.
Thankfully these trucks are fairly high off the ground, so I can sneak under there and do what I have to do.
Thanks guys!!
Old Apr 14, 2007 | 06:16 PM
Mason Dixon's Avatar
https://www.yotatech.com/forums/f2/removing-transmission-pan-2-quick-questions-106605/
Old Apr 15, 2007 | 07:42 AM
bmwpower's Avatar
Don't know how I missed that thread, I must have looked for 30 minutes or more for something. Thanks!
CORRECTION (on my previous post)...you have to remove the swaybar to get the pan BACK UP...unless you want sealant all over your filter/screen (ask me how I know).
So after I had everything ready to go, I get under the truck on the ground to find out that it's not going to go back on like the way it came off. I had to lift the truck again and remove the swaybar....BROKE ONE OF THE BRACKETS in the process. You should have heard the curses flying. Not fun when you're sealant is in the process of drying up.
So I ended up having to drill out the remained of the stud on the broken bracket and put a regular bolt on instead. That should hold now until I get a new bracket and bushings - boy were they shot.
crammit442
7
Nov 29, 2017 12:30 PM
Sep 4, 2015 09:27 AM
irritech
Jul 27, 2015 05:15 PM
rchavis
Jul 27, 2015 07:41 AM
Jnkml
Jul 6, 2015 01:20 PM
