How to fix busted sensor mount?
Old Nov 24, 2019 | 05:32 PM
kaylee34's Avatar
Help please again guys.
1998 3.4L
So the 4runner was finally fixed has been behaving nicely until a few days ago.
Suddenly and instantly started running rough all the time and shuddering when you give it a little gas.
Code said crank position sensor. Friend tried to swap it for me since my hand is broken and he made a muck of it. He didn't just bust the head off the rusty bolt, he broke the side out of the mounting tab where the bolt goes in. The bolt is still frozen in there. You can see the length of the whole thing from underneath. The hole for the sensor itself is fine.
So what now? How would you fix this? Is that mount thing
even a part I could order and replace fairly easily?
Old Nov 25, 2019 | 03:23 PM
fierohink's Avatar
The good news is that bolt isn’t under a lot of tension. With that said, you should be able to fix this with some JB Weld. There are a few ways to repair that are closer to by the book and some that are definitely cutting corners.
the text book method is to remove the remain long bits of old bolt, mix up some JB Weld and build up that broken ear, allow to dry, grind the face flat and tap the threads for a replacement bolt.
Personally, I would do most of that above. With the shortcut that I would put a piece of all-thread in the remaining threads and JB that into place. Then once it’s all dry I would secure the sensor with a nut.
Old Nov 26, 2019 | 05:20 PM
aowRS's Avatar
This.
Andreas
Old Dec 9, 2019 | 03:05 AM
kaylee34's Avatar
Thanks very much guys. I’ll let you know how it goes.
Learning
Nov 18, 2019 07:12 PM
plowzilla
Aug 12, 2013 09:14 PM
MAD MARK
Aug 10, 2011 11:58 AM
Junkers88
Apr 6, 2009 09:43 PM
89needsatranny
Jan 2, 2009 06:30 PM
