how can i turn off my keyless entry chirp?
Old Feb 25, 2008 | 05:47 PM
4rnr4nick's Avatar
on my 99 4runner? i HATE the chirp! anyone know of a way to turn it off?
Old Feb 25, 2008 | 05:49 PM
nix4x4's Avatar
X2 somebody chime in I wanna turn mine off on my Tundra
Old Feb 25, 2008 | 05:55 PM
wjwerdna's Avatar
ooh, ooh... I can find this answer... check back in a few minutes.. seriously
Old Feb 25, 2008 | 06:00 PM
wjwerdna's Avatar
Dealer tried charging me about $50 to do this before... that was before my Viper Alarm anyway...
Here ya go, VERY EASY
Old Feb 25, 2008 | 07:22 PM
4rnr4nick's Avatar
That lets me turn the sound down a little, but I wanna turn the chirp off...
Thanks! any more ideas?
Old Feb 25, 2008 | 07:30 PM
element's Avatar
This may help:
Disable Keyless Entry Chirp - 2001-2002 4Runners
Old Feb 25, 2008 | 07:35 PM
wjwerdna's Avatar
Old Feb 25, 2008 | 07:37 PM
element's Avatar
At least you didn't post ear plugs!
Old Feb 25, 2008 | 09:17 PM
4rnr4nick's Avatar
It was simple. wjwerdna, that worked and helped some, but i wanted the sound gone.
Open the hood.
Disconnect the chirper at the electrical connector.
Done.
The lock/unlock works and lights flash, but no annoying chirp.
Thanks guys! and good luck with yours! took me about 60 seconds!
Old Feb 26, 2008 | 03:48 AM
wjwerdna's Avatar
Lol... cool, well out of the two suggestions, both basically helped I hope, and the TSB at least shows the location of the chirper if the second suggestion came into play I always liked the chirp for the sole reason I could hear whether or not it locked
I just installed a Viper Alarm a while ago, much more annoying chirp, and don't need the chirp since it displays on my keyfob whether it is locked or not... only fun thing about it is that I can lock/unlock the truck from inside at my desk, making it chirp, right when people walk in front of it... I need to find something better to do with my time =)
Old Feb 26, 2008 | 06:48 AM
Sloan's Avatar
what about the panic button?
Old Feb 26, 2008 | 07:25 AM
Albert.G's Avatar
hhahah no way man...the only reason im putting in my alarm this week hahah i kidd...stupid thief's
Old Feb 26, 2008 | 12:46 PM
4rnr4nick's Avatar
well panic wont do anything anymore sloan...but i dont plan on EVER using it...so w.e.
Old Feb 26, 2008 | 02:15 PM
Rock Slide's Avatar
really, you're panic button will no longer work...I've disabled my keyless entry chirp and my panic button still operates properly. Sometimes I hit it mistakenly, and my horn starts sounding off like crazy.
Or is it b/c you've done something differently to make it stop working?
Old Feb 26, 2008 | 02:39 PM
Whitey13's Avatar
Only thing worse than that is when I accidentally roll down the rear window. Rolls down, but doesn't roll up. For shame Mr.Toyoda.
Old Feb 26, 2008 | 03:35 PM
4rnr4nick's Avatar
OH the panic DOES still work! I figured it used the chirp, but I guess it uses the actual horn?
SWEET!
im always too far away to roll down the window by accident...how far will ur guys' remotes work from?
Old Feb 26, 2008 | 03:56 PM
Whitey13's Avatar
Battery life significantly affects the remotes effective distance. I can't really say how far I can roll down the window from because it's usually a surprise when I get back to my truck.
Old Feb 27, 2008 | 04:45 AM
Rock Slide's Avatar
SWEET!
Correct, the panic button sounds the horn, not the chirp. Just press and hold the panic button, you'll find out real quick what sounds .
I'd hate to know that if my wife ever felt the need to sound her panic button, that only the chirper would sound...no one from any distance away could hear that.
I believe most oem 3rd gen remotes only have about a 20-25ft range. Sometimes I can operate the remote from further away, but often times, it's less than that. Also, it seems I can only roll my rear window down from further away than I can actually lock/unlock my doors...go figure.
Old Sep 11, 2008 | 03:13 PM
civilpd's Avatar
Search RS3000. There is a tech manual online I have downloaded but do not have it with me here. RS3000 should be the name of the alarm.
Old Sep 11, 2008 | 06:46 PM
Rock Slide's Avatar
The original question was answered back in February...
