Electrical Electrical and wiring
Disable Keyless Entry Chirp - 2001-2002 4Runners
Old 01-11-2007, 07:55 AM
Tech Article Editor
Writeups@YotaTech's Avatar
Article By:
Rock Slide
Application Vehicle: 2001-2002 4Runner with VSC & TRAC Systems
The purpose of this mod is to show you how to disable the keyless entry chirp common on 2001 & 2002 4Runners.
I use my keyless entry remove A LOT and get tired of hearing the chirps associated with it every time I lock and unlock my doors with my remote.
Tools Needed:
1. Duct Tape
2. Zip Tie
3. A socket wrench is optional.
Step 1:
Locate the OEM Buzzer found in the engine bay on the passenger?s side next to the firewall.
(Notice I have already unplugged the connector from the buzzer.
Sorry, no before pics. In normal operation, this connector would be plugged into the buzzer.)
Step 2:
Unplug the connector coming into the buzzer as I have already done in this picture.
Step 3:
Take some duct tape and tape off the exposed connector.
If you plan on using your buzzer in the future, do not remove it and you?re done!
If you never plan on using the buzzer again (like me), proceed onto Step 4.
Step 4:
Take a socket wrench, 10mm I believe, and remove the bolt holding the door buzzer to the body and do with it as you wish.
(I personally threw mine away.)
Here is the part I discarded:
Step 5:
Take the connector and zip tie it to something close by to keep it from flopping around in the engine bay.
No pics where I zip tied the connector too. Just pick something close by to zip tie it to.
Any questions about this article, please contact Rock Slide, and not Writeups@YotaTech
Flying91
45
04-11-2024 04:39 PM
coreyedwards7611
01-16-2016 06:38 PM
BeMiceElf
10-10-2015 09:40 PM
Poppie51
07-23-2015 05:03 PM
Poppie51
07-16-2015 06:16 PM
Quick Reply: Disable Keyless Entry Chirp - 2001-2002 4Runners
