hood not latching after hood protector installed
Old Aug 9, 2006 | 11:20 PM
kronah's Avatar
Has anyone had trouble latching the hood after installing an aftermarket bug shield. I attempted to install the shield last night; lined it up, drilled the holes, and fastened the included screws. The only problem I had was when I tried to close the hood it would not completely latch. The instructions state that I may have to adjust the hood lock mechanism to allow for the thickeness of the hood protector. I looked at the lock mechanism and it doesn't look like an easy task to adjust. Is this something that is easy to do or should I take it to the dealer to adjust? Thanks in advance for any help.
2002 Limited 4WD 4runner
Old Aug 10, 2006 | 04:22 AM
waskillywabbit's Avatar
The hood latch mechanism is attached via some bolts...and IIRC the bracket has slots in it for adjustment.
Old Aug 10, 2006 | 07:09 AM
eric-the-red's Avatar
Like the wabbit said it's attached by bolts, simply loosen the bolts on the latching mech behind the grill and move it up a bit. I have an 01 and I really can't rmember if the holes are slotted but there should be some adjustment. I have a Toyota hood protector and mine didn't need any adjustment.
Old Aug 10, 2006 | 03:14 PM
kronah's Avatar
I'll see tonight if I can adjust it myself.Thanks for the replies.
Old Aug 10, 2006 | 03:20 PM
seanz0rz's Avatar
Guest
dont remember on the toyota(havent looked under the hood much since i got her, checked the engine, it was there, that was about it)
you may have to lower the bump stops that probably sit in the neighborhood of the headlights. they are bolts with rubber tops.
raising the lock mechanism is going to lead to your hood not fitting "right". the extra thickness of the bug shield is causing it to hit the stops prematurely, not allowing it to lock.
nevermind, i correct myself... on my 98 there are fixed rubber bump stops, no adjustment of those. unsure of what you can do, short of move the latch.
Old Aug 10, 2006 | 08:36 PM
ecchamberlin's Avatar
MIne did make it fit very tight. I have to drop the hood from about 10 inches to get it to latch but it still releases fine.
Old Aug 11, 2006 | 04:44 AM
Rock Slide's Avatar
I currently have an EGR bug shield on mine and I did not have to make any adjustments. I've also owned Toyota brand and other brand bug shields before on 4Rs w/o having this problem. But then again, I've also never had to drill holes in my hood. The one's I've owned fit into pre-existing holes in the hood.
What brand of bug shield do you have? May keep me from buying that one in the future.
okamikai
Apr 30, 2018 10:19 PM
raptor510
Feb 17, 2017 07:11 AM
mr_manny
Jul 31, 2015 10:39 AM
jjrbus
Jul 19, 2015 02:06 PM
bryan34w
Jul 6, 2015 05:53 PM
