hi lift jack mount
Old Aug 19, 2005 | 12:17 PM
Swissdrums's Avatar
hi lift jack mount
Hey all,
I thought of a good place to mount a hi lift jack...
I am planning on seeing a possible way to mount my jack where my rear window wind deflector is. 2nd gens...
Has anyone ever tried this yet?
-mike
Old Aug 19, 2005 | 12:45 PM
4x4Lamm's Avatar
Uh, better not. That much weight being subjected to bouncing. Its gonna rip out and hurt somebody, plus damage your 4x4.
Lamm
Old Aug 19, 2005 | 12:57 PM
Swissdrums's Avatar
true...
Old Aug 19, 2005 | 01:42 PM
4x4Lamm's Avatar
Not trying to be mean, but they weight a ton. Try a safari rack with the jack mounts, that would be cool.
Lamm
Old Aug 19, 2005 | 01:45 PM
Good Times's Avatar
I've see some cool setups:
* mount it on the sliders. The base and the lock mechanism was stored in the box in the trunk (and stays clean too).
* mount it to their front bumper or rear bumper both aftermarket.
* mount it to the roof rack (either using a basket or some kind of attachments)
* in back
Good luck!
Old Aug 19, 2005 | 01:48 PM
4x4Lamm's Avatar
The easiest thing to do is put in in back with the base on the cargo floor, use rope and two tie dows for that. then remove a backseat headrest, lay the climber bar on the back of the back seat and replace the headrest with one of the poles going through a hole in the jacks climber bar. This is eash, cheap and safe.
Lamm
Old Aug 19, 2005 | 08:06 PM
Swissdrums's Avatar
alright, thanks man, i will see what i can do...
-mike
Old Aug 20, 2005 | 01:10 AM
4ROMPER's Avatar
I'd hide it in the cargo area... saves the price of mounts, locks, etc. Plus, much easier access than a roof mount... Well, depending on the height of your rig to your height ratio...
Old Aug 20, 2005 | 07:28 PM
bktaco's Avatar
i've probably posted this before, but here's another low cost option with zero bling factor.
i have been dis-assembling mine into 3 parts - i soak the hell out of the walking mechanism with wd-40, wrap it in a towel, and stow it in my milk crate recovery box. i stow the walking bar flat against the front of my truck bed (anywhere will do, pref out of sight). then i stow the lever bar in an easy to reach location behind the drivers seat. it doubles as an ugly stick if i should ever need one. as you know, the jack goes back together in about 15 seconds if youre not in a rush.
Jun 1, 2021 01:51 PM
shisha1999
Aug 14, 2015 01:33 AM
nickbeauregard
12
Aug 7, 2015 06:04 AM
Sr5crawler
Jul 31, 2015 12:32 PM
coffey50
Jul 28, 2015 10:55 AM
