hi i got a question about the roof rack
Old Jun 11, 2003 | 03:59 PM
theknown4runner's Avatar
Post hi i got a question about the roof rack
how do i take it off? thx
Old Jun 11, 2003 | 04:06 PM
calrockx's Avatar
methinks you mean the factory one...you should be able to take it off with just a screwdriver. you take off the caps at the end of the rails, unscrew them then slide them off. the crossbars come of real easy too. you may need one of those funky star shaped screwdriver bits to unscrew it, i'm not sure...that comes to mind tho (it may just be the yakima roofrack i'm thinking of tho).
Old Jun 11, 2003 | 04:10 PM
Bob_98SR5's Avatar
Easy,
Take off the cross bars. If you can't figure that out...
From there, you'll need a #24 torx bit. Unscrew all the torx screws about halfway which will relieve the tension off the front and rear end caps. Gently pry off the end caps w/ a flat bladed screwdriver. Then you can unscrew off the torx screws and lift the whole thing off.
Bob
Old Jun 11, 2003 | 05:08 PM
TDiddy's Avatar
Wow, Bob nails it right down to the size of the torx bit!
Old Jun 11, 2003 | 05:22 PM
calrockx's Avatar
wow, i'm impressed. you know, i could have said all that, but i wanted the guy to have to figure SOMETHING out on his own
jk. but now i know what that kind of screw is called. cool.
icentropy
Sep 16, 2020 02:47 PM
Medic22733
Aug 10, 2015 06:49 PM
priest16
15
Aug 6, 2015 07:43 AM
defrag4
Jul 31, 2015 10:50 AM
HaydenConQueso
Jul 12, 2015 05:22 PM
