Help with TSB's...
Old Aug 30, 2004 | 07:33 AM
Help with TSB's...
Is there a site for TSB's? I recall a TSB that I never acted on. I have a '96 Runner that buzzes when I turn it off, the buzzing continues intermittently for days!
Thanks,
Emil
Old Aug 30, 2004 | 07:42 AM
waskillywabbit's Avatar
Talking
http://www.alldata.com/
Search by make, model and year.
Old Aug 30, 2004 | 08:06 AM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
also:
http://www-odi.nhtsa.dot.gov/cars/problems/tsb/
Old Aug 30, 2004 | 08:09 AM
BajaRunner's Avatar
I have that exact same problem.
Mine comes from the drivers side, near the fuse box and master cylinder.
Old Aug 30, 2004 | 08:41 AM
bradym239's Avatar
Okay, so I am TOTALLY uninformed. If I found two (relating to the same problem) TSBs for my truck. What do these mean for me? How do I use them to get the problem fixed? Any and all help is greatly appreciated.
Regards,
Brady
Old Aug 30, 2004 | 11:01 AM
User 051420's Avatar
If you need specific TSB details I can get them for my 97 runner. I'm a member @ alldata.
Old Aug 30, 2004 | 12:20 PM
Hey, that would be great, I think the number is EG00297. That should be for the buzzing Evap Canister. Will that show me how to fix it or do I need to go through the dealer?
THANKS AGAIN!!!
Emil
Old Aug 30, 2004 | 12:29 PM
rimpainter.com's Avatar
The buzzing is caused by the EVAP canister. If you put your ear by the canister, you can narrow it down to a line that plugs into a big round looking thing attached to an even bigger box (the canister). If you pull that line, which comes from the fuel tank, it will stop the buzzing; however, it will also release fuel vapors (you will smell it, trust me) into the engine compartment, which is not good.
Your best bet is to get the upgraded part from the dealer. Personally, I don't care about the buzzing so I just let it go.
Old Aug 30, 2004 | 01:35 PM
Emil: Here's the page from Alldata.com. If it doesn't work for some reason I'll PM you my username & password and you can have at it!
Clicky
Old Aug 30, 2004 | 02:07 PM
Perfect. Thanks very much!
Old Aug 30, 2004 | 03:19 PM
BTW Emil: Where do you go wheelin in Casper? Riverton seems to be pretty well consumed by private land.
EDIT: Wanna race sometime?
Old Aug 31, 2004 | 06:07 AM
I don't want to race you, you have a cupholder mod!
I mostly stick to BLM lands, a few small areas around Casper.
Old Aug 31, 2004 | 06:10 AM
You forgot about the TRD Stickers..........
jacked_72
Sep 14, 2015 03:31 PM
1996Taco
Jul 20, 2015 12:02 AM
The Dutch Man
May 17, 2004 12:48 PM
bobzemuda
11
Dec 22, 2003 10:32 PM
